Question about Refrigerators
Sub Zero 361 RFD is there a separate setting for the freezer?
Is there a separate setting for the freezer?
JOE LLAMA
  • 26 Answers
SOURCE: Sub Zero Freezer Vacuum
If your freezer temps are ok, it may just be that your gasket is getting older and it becomes more porus as it ages. The vacume sound doesnt really mean alot except that the difference in the room temp and the cold of the freezer create this vacume.
Posted on Mar 31, 2008
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
SOURCE: sub-zero model#3211-rfd, side by side,
Have you cleaned the coil? Pop the grate off the top of the fridge and vacuum the coil as well as the grate thoroughly.
J
Posted on Sep 16, 2008
  • 1462 Answers
SOURCE: Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Posted on Sep 25, 2008
SOURCE: sub zero freezer too warm
I believe the freezer has to get down to 7 degrees or lower for icemaker to harvest. Clean your condenser and blow it out. If that doe not fix it you will need service for sealed system
Posted on Oct 08, 2008
Where is the fan on the freezer side that cools the fridge on sub zero 690
The freezer section has its own fan and the fridge has its own fan motor. The two systems are separate from each other and does not share air. The Fan in the freezer is located behind the ice maker in the freezer section.
I hope this helps.
Oct 13, 2013 | Sub-Zero 690 Side by Side Refrigerator
Turning off a sub zero 3211 rfd
replace the thermastat. the switch in the question I mean the contacts inside are stuck or fused closed and are not disconnecting when the set point is reached.
Jan 01, 2013 | Refrigerators
Does the sub zero model 361 rfd refrigerator have a separate thermostat control for the freezer ?
No, the 361RFD does not have a separate control for the freezer as this unit has a single compressor. The control is located behind the back panel in the refrigerator compartment and the part number is 4201470.
Jul 21, 2012 | Sub-Zero Refrigerators
Is there a water filter for the ice maker? i need an owners manual for my sub zero model 241 RFD...
If you have a filter on the refrigerator, then all the water/ice that comes out of the refrigerator first passes through the filter.
Oct 20, 2009 | Refrigerators
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-zero model#3211-rfd, side by side, freezer working fine, but refrigerator not cold enough, alwaus stays 40F, even i turn to the max.
J
Jul 30, 2008 | Sub-Zero Refrigerators
Refrigerators Logo
275 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
