Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire gleq2152es0 dryer will not heat up. Runs just no heat.
Operates fine just not heating up. removed rear panel and top panel but didnt see any fuses or breakers
  • Anonymous Apr 26, 2009
    my clothes dryer no longer heats up. Before bying an element unit, should I check any fuses or switches first for replacement?
    Genius:
  • 1,198 Answers
At most you may find a relay in a dryer. They're usually wired pretty simple. Keep in mind that 220 comes from both wires, and meets in the middle, the load. Be careful if you test live! A control may break just one wire. At a failed component, you'll have 220 on both legs, but no go. Jumping that component will make the unit run. Don't jump the elements!!! You can put a false load where the elements go, but it must be 220 volt, like two lite bulbs in series. I make my tester out of two lite bulb pigtail fixtures wired in series. At 110 they glow less bright then at 220.
Posted on Apr 21, 2009
Maytag 8114p732 60 stove top works, oven does not
Check the heating element,to make sure it has a good connection,turn power off and remove,inspect,may need replacing.Also check circuit breaker at power box.
Nov 20, 2012 | Washing Machines
Rear defroster inop
easy fix is sometimes the "circuit breaker" in the inside fuse panel, on GM products they are likely silver colored and pull out and plug in just like a fuse. Some car makers have the diagram inside the fuse cover which makes it convenient to see which fuse or breaker applies to the defogger. you can switch identical cir.brkr.s with each other to see if then it operates. then get a new one from your parts store. I switch the power seat relay with the rear defrogger relay and this confirms my check before spending any money. good luck keith
Dec 30, 2011 | Cars & Trucks
Turns on no heat
The very first thing to check. If you are on a fuse panel check to make sure both 30 amp fuses are ok. One fuse operates the motor and timer, but requires two fuses to operate the heat. If you are on breakers, turn the breakers off and wait a few minuites and turn back on and test.
Jan 21, 2010 | Maytag MEDB800VQ Dryer
Dryer won't heat up but tumbles. What could be
you could have a bad heating element, a tripped circuit breaker, a blown fuse in the dryer or a bad timer. you can check the element and fuses/ thermostats with an ohm meter for continuity.
Sep 17, 2009 | Dryers
Dryer won't dry
Without a meter there is not much you can do but a couple things to try , 1st turn the breaker off , when turning it back on push the breaker switch firmly in toward the panel then check for heat . the breaker may be running only half power and not supplying the heater [bad breaker] , the next thing is the temp. fuse on the heating element case. take the ;arge back panel off of the unit , you should see the element case on the right , it should have 4-6 red wires going to it , the fuse is located at the top of the case , remove the 2 red wires from it and slide them together then use electrical tape to tape them carefully power unit back up and test for heat , if it is working now you most likely have an exhaust problem , check the airflow where unit exhaust. let me know if you have any other questions.
Phil
Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
1999 a6 steering wheel melting...!
On the extreme left of the dashboard where the door seems to make contact with the dash, there is a "D" shaped panel that can be pried off by sticking a very thin screwdriver or similiar object in the notch. Once the panel is off you will see a cluster of fuses from 5 to 30 amps. On the panel you removed you will see a label indicating which fuse operates which electrical component and the size of the fuse. The fuse that operates the heated steering wheel warmer should be # 27. You may find that the fuse is not blown but for some reason the warmer is not working. For safety you can still remove the fuse. I think in the Avant this fuse also operates the rear windshield wiper.
Nov 02, 2008 | 1999 Audi A6
Maytag MDE2400AYW Dryer Heating Elements not staying on
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 30, 2008 | Maytag MDE2400AYW Neptune Electric Dryer
Whirlpool dryer
    You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Oct 22, 2007 | Whirlpool LER5636P Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
800 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
