Lexmark X4270 All-In-One InkJet Printer Logo
Kevin Schraeder Posted on Sep 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't send or receive faxes
I'm trying to fax something and it just sits there. I try to receive a fax and it answers the phone, then just sits there. There is no handshake tones or nothing. What needs to be done to get the internal modem working? I have set date/time, etc. which I thought would work, but didn't.
mukhtar21 shaikh
Level 3:
President:
  • Lexmark Master 2,022 Answers
  • Posted on Sep 22, 2007
mukhtar21 shaikh
Lexmark Master
Level 3:
President:
Answers
2022
Questions
Helped
669264
Points
5817
See your phone line is working or not try with connect a telephone and see r u able to make a call or not. bye
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Peoplel are sending me very imp. faxes and idk how to recive it..
If your printer has FAX capabilities. Good way to tell is if you have a phone number pad on the front of your printer.
You must have this connected to a phone line for it to receive a fax.
Setup the fax application through your installation CD that came with the Printer/fax machine. Often you set the fax machine to pick up after so many rings. This allows you to leave the printer/fax machine on and gives you time to answer BEFORE the fax machine does. If uncle Bob or Aunt Susie should call to say Hi!
Basically what is happening:
You turn on the Printer/Fax machine it sits idle waiting for a phone call.
Someone now sends you a fax using your phone number.
YOUR printer/fax machine is sitting there listening for the phone to ring.
Lets say you have your printer/fax machine setup to answer after 5 rings.
After 5 rings, your Printer/fax machine will pick up and listen for signal tones from the the other machine. If it gets these, it will "handshake" and send a confirmation fax tone. Then the data will be transferred and printed out on your machine or held in a fax program for you to print or save later.
It is critical that you do not pickup the phone too early or the two fax machines trying to communicate will fail.
If you do this, you will hear an awful squeal and a serious of tones.
You can often hang up quickly and the two machines will transmit again the handshake signals and resume business as usual.
Short answer:
Two fax modems are talking to each other over your phone line to transmit data.
and hope this is helpful.
4helpful
My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
1helpful
Can send but not receive faxes.
Fax machines won't work reliably on a digital phone line.
2answers
LEXMARK X5495 New printer, can't send receive faxes
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines
"no answer"
Call the number from a regular phone line and listen for fax tones. No fax tones....it's not a fax machine, or the recipient has their fax machine set to MANUAL RECEIVE.
1helpful
Dell 962 printer
Remote fax error means there is something wrong on the receiving end, not with your fax.
It could be that it can't negotiate the handshake with your machine (that static noise it makes when it first connects).
Or it's not set to a receive mode.
Have you tried just calling the remote fax with your phone to see if you can hear that it is in a recieve mode (you'll get the static) or that it's not going to an answering machine by mistake (a common problem)
Fax
HI,
u need to make change to answer ring pattern from the front panel of unit .
Set the fax function to answer the phone automatically by pressing the auto answer mode button on front panel .
Thanks
2answers
Still Cant send out a fax
hmmm..did you call your fax? give me the number of your fax, and I'll call it first, then fax something to see if it's on the receiving end(which could be the case)
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
