Question about Panasonic CT-30WC14 30" TV
TV won't turn on. (Panasonic 1080i HDTV)
We have had the TV for 6 years - no problem. This morning when it was tried to turn on, it wouldn't. The power button is just sitting there with the power button blinking. I have already tried unplugging it and all. I have a similar problem the power light won't even come on when i plug it in. If i leave it unplugged for a while and plug it in, it sounds as if power is coming on but nothing happens. model # ct-30wc14j hdtv 1080i 2004 model for some reason the c14j is not a valid product but thats what it says on the back of the tv ' _ '
    Sergeant:
  • 197 Answers
By the sound of it its a dead power supply im afraid :( It is very common for them models at that age very common... it may be cheaper to fix then buying a new one but ill let you decide that one but yea theres hundreds of people that have the same problem with them panasonic's bummer dude :(
Posted on May 04, 2017
mediarich
  • 188 Answers
SOURCE: Unable to view fullscreen in hdtv
That is the way HDTV is viewed on many screens as a wide fromat. So you will get top and bottom non-viewable areas. It is the width that gives the full imagery for that format. To have the screen filled you would get a standard 4:3 format like standard TV. HD is a 16:9 format so it is much wider.
Posted on Sep 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV won't turn on. (Panasonic 1080i HDTV)
The power led blinking is an error code if you can reply to this same post and let me know the number of blinks I can assist you with what it means.
Posted on Jan 24, 2009
SOURCE: The TV will not turn on
transister on tube blew out, needs new tube, could be from storm
Posted on Jul 02, 2009
johnnydiode
  • 647 Answers
SOURCE: panasonic CT-36HX42F I turn it on and then, turns off
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom.
The only way to determine the real cause is #1 an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
Posted on Sep 20, 2009
dave1645
  • 834 Answers
SOURCE: I have a panasonic 32'' hdtv that may need a thermistor
there is a diode gone bad in the power supply have a tech come out and replace it
Posted on Nov 24, 2009
Do my panasonic hdtv 1080i need a converter box in order to work?
None of the newer style TV's need a converter box because all the tv channel tuners use a digital signal. The tv signal in the air is now digital when using a tv antenna.
Sep 13, 2015 | Panasonic Televison & Video
Why is my panasonic hdtv 1080i on off switch blinking red
thats usually an error code. How many times does the light blink?
Apr 02, 2013 | Panasonic PT-53WX53 53" Rear Projection...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
How do i turn on an hdtv 1080i on?
You don't "turn on" 1080i, the TV receives a signal that is in that format and displays it. If the antenna or whatever you have is not giving a High Def input to TV, it can't display HD picture.
Dec 22, 2009 | Panasonic Televison & Video
I have a Panasonic HDTV 1080i 52inch TV that is 6 years old. When I turn it on, the green power light just blinks and there is no picture at all. Any advice?
Check the lamp. Detach the front cover, read the warning, unscrew the cover, look inside, undo the one and only screw you can find, and pull out the lamp module. (Without touching the lamp) have a look at the light. Can you see it smokey in colour, or is the filament broken? This is how the PT-50LC13-K that I found in the garbage behaved, and the lamp filament is toast. Just thought I'd share.
Oct 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
Aug 23, 2009 | Panasonic Televison & Video
thats the error for the convergence ICs You will need two STK392-110 Convergence ICs you can get replacements at the following link.
http://servicemanuals.vstore.ca/
Apr 21, 2009 | Televison & Video
Jan 24, 2009 | Panasonic PT-53WX53 53" Rear Projection...
My panasonic HDTV bbl 1080i was purchased about 6 or 7 years ago. The image shows two or three other images from the original image which are florence green and pink. So basically I see a triple image of...
I have a Panasonic PT-47WX53 rear projection TV and the picture was pretty dark for the last year but for game it was OK but know the blue is out of sequence, do I need to change the lamps?
And where to find them?
Jul 26, 2008 | Panasonic Televison & Video
Panasonic CT-30WC14 30" TV Logo
297 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
