Question about Sony BRAVIA KDL52XBR2 Television
My Sony Bravia remote control is slowly loosing it's functions.
My Sony Bravia's remote started loosing it's functions 3 months ago when the #5 stopped working; later the volume control went out; then the channel control; next the #2 and now the guide button.  I have tried replacing the batteries and cleaning the glass receiving area but it still doesn't work.  I assume it's a bad remote.  Any hints?
  • 41 Answers
You can repair some of these remotes. Usually the hard part is getting the cover off. they are not really made to be serviced. The problem with most all remotes that start doing what you describe is either wear or something spilled on it. You can fix it. Sony remotes may have 1 screw in the battery compartment. remove it and try sliding the front and back. If that dosen't work try prying from one side with a sharp edege. If you do manage to get it open take the PC board out. You will see a rubber like membrane that lays against the board. Try cleaning that with a qtip and rubbing alcahol. Then clean the PC board the same way especially where the pads of rubber contact the board. Make sure it's completely dry and snap it back together. If it works better good, if not the pads are to worn and you just have to replace. Good Luck.
Posted on Apr 21, 2009
My remote (RM-GD007) had a sticking volume control button. The way to remove the cover on this model is to use a sharp 3/4" wood working chisel. Place the remote face down on a bench and use the chisel to prise open the case along each of the sides (you will see a line where the front cover overlaps the back - work the chisel in to separate them. Once open, the rubber membrane can be cleaned with alcohol. My unit had a build up a grease like substance which was causing the keys to stick. Not sure where this came from. Good luck !
Posted on Mar 24, 2013
Sony Bravia sound works with rocker switch but not cable remote
Since your specifying cable remote I take it that your not using the remote that came with the Sony Bravia. Not all remotes will operate all functions of all devices. The cable remote may not have the correct coding for the TV your trying to control.
Feb 25, 2012 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
I have a sony bravia davhdx274 but i no longer
Yes, but you will have very limited control for internal adjustments.
You can purchase a new remote from www.remotes.com
or 1-(800)REMOTES and they will ship it to you within 5 days.
Good Luck !
Feb 09, 2010 | Sony BRAVIA DAVHDX275 Theater System
Remote control doesn't work ar all
get an all in one remote and see if that works they r very cheap to buy
Jul 18, 2009 | Sony BRAVIA KDL52XBR2 Television
Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Remote Codes for new Sony Bravia
0000 worked for my XBR4 using the remote called: Comcast Custom DVR 3 Device found here:http://www.comcast.com/corporate/customers/customer_support/remotes.html
Nov 17, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony bravia 46" remote control turns on the TV but no other buttons work
First, change the batteries on the remote with e new set of batteries. Check to see if you can bring up the menu using the buttons on the TV itself. Let me know what happens
Sep 25, 2008 | Sony BRAVIA KDL52XBR2 Television
Remote code for Sony Home Theater
This works for ALL Sony Home Theater Systems
Remote Code: 21232 (a Sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Function = 44750
Mute = 33743
Oct 29, 2007 | Televison & Video
Sony bravia lcd tv
Are you connected to a cable box or satalite rcvr using compoment outputs (y,pr,pb)? It is posible that the red cable has come loose and picture has no red,causing a mostly blue picture.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL52XBR2 Television Logo
1,046 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
