Question about Peg Perego John Deere Gator HPX Ride on Toy
Only goes in reverse after recent charging
Recently charged the battery and now the gator only goes in reverse and does not go forward at all. Took the gear shifter apart and both switches move easily and the connection from front to back, seems intact. I did take it apart to make sure no dirt was in the connection and it seems fine. Need help please.
  • 1 more comment
  • emc4kids Apr 28, 2009
    Mine will only go in reverse, replaced the hi/low switch and I still have the same problem,any ideas?
  • Anonymous May 05, 2009
    We just encountered the same problem. The gator is fully charged but will only kick into reverse. I need a solution also.
  • Anonymous May 09, 2009
    mine goes in reverse in the "1" and "2" gears. it will go forward in "R". so, everything is switched around.
I would replace the high/low switch and the reverse switch.
I had the same problem of it not going forward, but I just replaced the high/low switch. It turns out 1 month later I had to replace the reverse switch.
Here is the link to the site that I found my switches on.
http://www.shopjandl.com/mepu0003.html
Hope this helps
Posted on Apr 21, 2009
How do I get the M18 light to turn off it stays on all The time
If it's the white work light ? Has someone worked on it recently ? Does the work light go off when pulling trigger? Are the forward and reverse switched ? It could be the blk and red wires on the brush card assembly are switched.
Feb 20, 2015 | Milwaukee M18 Compact Drill & Impact...
Peg pergo John Deere Gator goes for about 2 seconds then stops suddenly
it almost sounds like a thermal fuse, but these don't have a thermal fuse, so id say it might be a bad shifter switch
Dec 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
My sons gator lost reverse, but still had forward 2 gears, then stopped working all together. I fully charged battery and still nothing. It will honk the horn, but wont move forward
horn runs off of a seperate power supply, check the battery nad charger with a multimeter and make sure that its putting out at least 12 volts
Jun 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
We charged the battery on my daughter's gator but it still won't work. It is about a year old. Do you think I need a new battery or is something else wrong with it?
The shifter switch has gone out, they go out alot. The price is not bad to replace it, and you can find it at mypegperegoparts.com . It is not the battery though.
Mar 07, 2011 | Peg Perego John Deere Gator HPX Ride on...
I recently recharged the battery after several months of inactivity and when the pedal is pressed the gator worked for bout 30 seconds and now doesnt work at all.... is it the pedal
unfortunatly probably the battery is toast if it was it stored outside in freezing temps? does it work after charging again for 30 secs? if so its probably the thermal breaker under the shifter, replace it with a 30 amp fuse. charge the battery and test it with a cheap volt meter form harbor freight (under $5). its probably not the pedal, but you try that, the switch under it is very cheap to replace.
http://peg-peregoparts.com/
good luck!
Jan 06, 2011 | Peg Perego John Deere Gator HPX Ride on...
Rascal scooter no forward or reverse or seat rise
Does the scooter have any power to it at all? Have you recently charged the batteries? If the scooter has been sitting unused for a while the batteries may not take a full charge and need to be replaced. If the batteries are good, check the fuses and all of the battery connections to ensure nothing has come lose. Sounds like a power issue.
Oct 17, 2010 | Electric Mobility Mobility Electric Power...
No forward gears just reverse
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
Jul 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
Gator goes forward in reverse and reserve in forward. Battery is hooked up correctly
there should be a wire harness on the back of the shifter to go forward and reverse try to switch it around
Apr 19, 2010 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
761 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
