Question about ASUS P5GD1-VM Motherboard
Raid 1 problem
Good morning,
I have raid 1 with 2 sata1 seagate 200GB tipe ST3200822AS.
my operating system is windows xp sp2.
one of the harddisk is broken ( there is an error message in windows )
I change the broken harddisk with a new 250GB sata2.
the rebuilding process can be finished but after I reboot the pc, my windows still shows error message for the raid.
please help
thanks and regards
Po Hoat
  • pohoat Apr 21, 2009
    hello Rjivaro,
    thanks for the advice. we have done like what you said.
    sorry to add :
    beside 2 harddisk, we have 1 cdrom, 1 cdrw, 1 agp geforce and 2 fans.
    is it possible the error caused by " a broken power supply"?
    thanks
    Novelist:
  • 153 Answers
When you are booting your machine, notice the prompt to press keys to get into your RAID controller. Press them and get in. You have to tell it that you want to use that new drive to rebuild your array. You really wouldn't want it any other way. Then when you boot windows it will be able to rebuild it and the message should become one of happiness, given adequate time to rebuild.
Posted on Apr 21, 2009
  • rjivaro Apr 21, 2009
    You are dealing with a computer, so really weird stuff is always a possibility, but 99.999% of the time it is pretty straightforward.
    If you are able to boot into windows, your power supply is fine. If windows reports RAID problems, it is because you have a RAID problem.
    Go back into the RAID bios and remove the new drive from the array. Reboot, and then go in again and tell it you want to use the new drive to replace the missing drive (again). Then boot into windows and give it all the time it wants to rebuild. If you get error messages, let me know exactly what they say as well as what motherboard and processor and RAID card you are using.
Cd kit 394378-002
The windows XP operating system has several versions. Computers with the default windows XP operation system only requires updates to the versions of SP 1 or SP2 that are improved versions over the default to achieve experinces. The windows XP operating system version SP1 and SP2 are installable with the first default version beign present on the computer. Also, computers that are least windows XP compartible are incapble of crossovers to SP1 or SP2. Windows XP default on the computer makes possible system conversions however. Windows XP operating systems computers allows to acquire from software retails to replace malfunctions. Ascertain the computers compartibilities and with the version of the default system as referece to acquire the most appropaite operating system at retail.
Feb 05, 2011 | Microsoft Windows XP Professional SP2
How to improve my harddisk...always hang up
You can do a regular maintenance.
1. Use the CCleaner to clean up the craps.
2. Malware/Spyware, Virus scan and remove any threats!
3. Uninstall any programs you longer use or remove any old data you don't need to increase your HDD capacity.
4. Defrag your HDD. (You can use the Defraggler)
5. Do a "CHKDSK /f/r" for the Dos prompt for you HDD. (ie. Check the intergrity of your HDD)
6. Update your Windows System from Microsoft Updates.
Hope it helps.
Nov 06, 2010 | Microsoft Windows XP Professional SP2
I have a Seagate ST3200822AS 200 GB Hard Drive(windows XP).I want to use this as external but I don't want it to mix with HD on new computer(windows 7). How do I keep them separate and run one or the other...
Is the Seagate ST3200822AS an External Drive ( like USB connectivity ) or actual Hard Drive ? Even if it is Internal Hard Drive, You can make connect it to Win 7 and still keep it as Seperate Drive.
Connect the Hard Drive to Win 7 PC and Make it Slave ( partition ) by changing the Jumper on the Hard Drive ( jumper is a small pin or a lock that makes a Hard Drive Primary or Slave.
Once you connect the HD to Win 7, you will find new Drives Created in Win 7, this way you will differentiate between the Win 7 Drives and XP Drives
This link will how you the jumper position : Remove the jumper from slot 1 and put it in slot 2
http://www.google.com.sg/imglanding?q=changing%20jumper%20on%20Hard%20drive&imgurl=http://www.mysuperpc.com/build_your_own_computer/sata_hard_drive_connectors_jumpers_cr.jpg&imgrefurl=http://www.mysuperpc.com/build_your_own_computer/pc_install_sata_hard_drive.shtml&usg=__iTyJjkCN501Kstme6LZ42u0Q3ZU=&h=538&w=600&sz=95&hl=en&um=1&itbs=1&tbnid=2EXt5zyA0OXYxM:&tbnh=121&tbnw=135&prev=/images%3Fq%3Dchanging%2Bjumper%2Bon%2BHard%2Bdrive%26um%3D1%26hl%3Den%26sa%3DN%26tbs%3Disch:1&um=1&sa=N&tbs=isch:1&start=8#tbnid=t42Gq31Rw32OCM&start=13
Jun 30, 2010 | Seagate ST3200822AS 200 GB Hard Drive
I can not setup windows xp in my dell latitude e6400 laptop.I set BIOS (F12), select "System Configuration", "SATA Operation" and i change it from "IRRT" to "ATA. But no work.When i start windows xp setup...
Try this hints:
1.Press F2 to enter BIOS on start up
2. Expand Drive section
3. Go to SATA Operation
4. Check and change from Raid Auto/ AHCI to Raid Auto/ATA
Good Luck
Apr 11, 2010 | Dell Latitude E6400 Laptop
Not Changeing sata to ata
You will need to go into the BIOS and disable SATA RAID. then windows XP setup will show the HDD.
Jul 02, 2009 | Microsoft Windows XP Professional With...
Install window on a portable ide harddisk
i dont think so dat window could b installed on usb.
Dec 31, 2008 | Computers & Internet
Hard disk problem
hmmm try to make SATA disabled from your BIOS setup. Because windows XP SP2 don't have any SATA driver, its came up with only IDE.
Try to disable your SATA it will fix your problem.
Thanks
Iqbal
Mar 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Pci ide raid card problem
Could be a PSU problem. What wattage PSU do you have?
Jan 31, 2008 | Sabrent SBT-RDIT PCI IDE Silicon Image...
RAID 5 installed with Windows XP sp2 now the DVD ROM and ROM not present in Windows
It sounds like your system may be confusing your dvd drive and somehow including it in the raid array or something.
Does it see it without the raid setup?
Jan 09, 2008 | MSI P965 Platinum Motherboard
My dvd rw is not detected
When installing SP2 version, you possibly corrupted the drivers for the DVD. It is possible there are different drivers for the DVD between XP and XP (sp2). Go to the laptop mfg website and download the newest drivers for the DVD.
Aug 20, 2007 | Microsoft Windows XP Professional With...
ASUS P5GD1-VM Motherboard Logo
165 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
