Question about Electrolux Refrigerators
WE HAVE A ELECTROLUX RM4400 FRIDGE IN OUR CARAVAN. IT HAS NO POWER CONNECYED TO IT AT PRESENT , NO BATTERY IN VAN AND NO GAS UTRNED ON THE FIRDGE IS INTERMITTENTLY MAKING A RUNNING CLICKING SOUND WHICH SOUNDS ELECTRICAL BUT CANNOT BE AS NOTHING IS CONNECTED. WE HAVE NO IDEA WHAT THIS IS? PLEASE HELP THANKYOU ROBYN.
Electrolux is now Dometic/Waeco & they said they have spare parts for the 4400 & to take ours to our nearest dealer. They could also tell us where in our state.
David
Posted on Feb 24, 2011
We would like to know when we leave the van not connected to the car, lets say on a ferry can the fridge run off the caravan battery and if so how do you set it up?
If its a three way fridge that runs off DC power you can, have a deep cell battery hooked up to your caravan power controller for the 12 volt lights, it will run for two days on medium setting.
Jun 25, 2017 | Cars & Trucks
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
Electrolux rm4400 fridge
check lines to ignitor for cobwebs
Sep 09, 2013 | Dometic Refrigerators
GE TBX23 will not get cold. It has not been run in a year. Any ideas?
the obvious things to check is the temp gauge inside the fridge. is it turned up far enough? if so, then the gas inside the fridge is no longer useable. meaning you cant use the fridge anymore and a replacement is required.
even though the fridge has not been used in over a year, the gas inside acts just like battery does, if a battery does not get used for so long, the power still runs out and eventually the battery looses its charge, the gas in a firdge acts the very same way
Jul 17, 2012 | GE Refrigerators
I NEED A USER MANUAL FOR ELECTROLUX GAS FRIDGE IN MOTOR HOME. MODEL IS RM 2260 AND PRODUCT NO. IS 9215430-01. GAS IGNITION SYSTEM NOT WORKING - THANKS FOR ANY HELP JAMES GREIG SMITH
Hello, here is the manual: -
http://web.me.com/danperkinsartwork/Autohomes-Bedouin/Manuals_files/Electrolux%20RM2260%20operating%20and%20instalation%20instructions.pdf
Also found this site with a list of parts for the fridge you mentioned
http://www.leisureshopdirect.com/Caravan/ventilation/Dometic_Caravan_Fridge_Spares/Dometic_RM2260_Fridge_Spare_Parts.aspx
Hope this helps, good luck
Aug 04, 2011 | Electrolux Refrigerators
My caravan fridge will not work on mains or 12 electric but it dose work on gas
The 12v power supply on the fridge takes a lot of power, and can only be used when you're driving. (When the engine runs.)
Regards,
Jul 09, 2011 | Electrolux Refrigerators
Electrolux fridge in my caravan will run on gas,
Hi it sounds time to pull it out and give the ignition box a good blow out to remove dust and cobwebs. Also remove the jet in the supply pipe where it screws on to burner box. Just wash and clean it dont poke anything in the jet hole. Graham
May 13, 2010 | Refrigerators
3 way fridge rm4400 not working on 240 volt
check the fuse, if its not a fuse, then the electric heater under cold plate is bad
Sep 04, 2009 | Avanti RM4400 Compact Refrigerator
Our caravan fridge electrolux rm4206 gets cold on both gas and 240v mains but does not seem cold enough ie freezer compartment is not quite frozen and fridge compartment is not cold enough. Any...
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Aug 27, 2008 | Electrolux Refrigerators
Refrigerators Logo
552 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
