Question about Toshiba Satellite A135-S4527 Notebook
20002 fordwindstar dipstick funnel broke how 2 fix it
How to fill your transmission fluid on a 2007 ford freestyle
Remove dipstick
insert funnel into dipstick tube
add fluid
remove funnel
insert dipstick and check fluid level
do not overfill
Oct 15, 2016 | Ford Cars & Trucks
WhereDo i add transmission fluid on 89 chevy celebrity
Remove the dipstick, insert a funnel. Pour a sufficient amount of fluid into the funnel.
Aug 05, 2016 | Cars & Trucks
How do i add transmission fluid, and where?
If you can see the dipstick pull it out & use a funnel & hose if U dont have a dipstick U need to find a bolt/plug at the top of the tranny on the left hand side take it off & attach a hose to a funnel & carefully top it up....
Jun 13, 2011 | 1998 Plymouth Voyager
When the dipstick was removed, the top of the tube to the engine broke off. How to repair please? Thank you
Plastic dip stick funnels are always snapping off.
Remove what you can see down to metal tube. With small hook on end of stiff wire, pull out inner plastic sleeve from tube.
If it won't come out...push it down so new funnel can be installed.
It can't hurt as the tube ends one eighth of an inch from the oil pan floor.
FYI. You need to cover top of new dip stick funnel with cloth and push home until you hear it click onto tube.
Jan 15, 2011 | 1999 Volkswagen Cabrio
I have a 2003 Golf. Recently i did an oil change to it and switched from regular oil to synthetic. After acouple of minutes of driving on the highway i started to notice white smoke coming from the exhaust...
Fix the dipstick funnel so you do not have oil dripping onto the exhaust causing white smoke. Some people delay fixing a bad oil pressure sender by running a thicker grade of oil. Synthetic oil tends to be thinner , from this you get benefits, in this case it probably exposed an oil sender that is in the process of going bad. If you put a new oil pressure sender in the motor(about$10) you should be able to fix the problem with the oil light.
Nov 08, 2010 | Volkswagen Golf Cars & Trucks
Where is the place to put transmission oil
The transmission fluid goes in the same tube that holds the dip stick that you check the fluid levels with. You will need a funnel, and be sure to use only manufacturer recommended fluid in your vehicle. Be careful not to over fill. Ensure the Galant is at operating temperature by driving it for about 10 minutes. 2: Open the hood of the Galant and locate the automatic transmission fluid reservoir and dipstick on the driver's side of the engine. The dipstick is labeled "ATF" and is red. 3: Pull the dipstick out of the reservoir, wipe it clean with a rag and reinsert it. Remove it once more and take the measurement of the current fluid level. Do not add any fluid if the fluid is already at the "Full" line; overfilling the reservoir can damage the transmission. If the measurement is between the "Full" and "Add" lines or below the "Add" lines, then continue to Step 4: Insert a funnel into the reservoir and pour a small amount of transmission fluid into the container. Check the fluid levels again by removing the funnel and inserting the dipstick into the reservoir. Pull the dipstick back out and read the fluid level on the dipstick. Continue this process until the fluid is at the "full" line. If you would like to do a transmission filter kit I have found a site with full color pictorial and instructions. Pretty handy!!!
Sep 05, 2010 | 2000 Mitsubishi Galant
How do i add fluid too the automatic transmission
Use a funnel and you add the fluid right thru the dipstick tube. Try not to overfill if you can this can cause the transmission to slip.
Nov 20, 2009 | 1990 Ford Probe
Where is the transmission fluid filler on ford fiesta 1996 auto
You need a medium-sized funnel; or a specially-designed transmission fluid filler funnel with a short hose attached to it (at Auto parts store for $5)... use a medium-sized funnel....
The filler tube is the same as the transmission dipstick tube.
Check the fluid level with the engine running, in park.
before adding fluid, turn off engine.
Insert the funnel into the tansmission dipstick tube, slowly pour in fluid (slowly!)..
In an emergency, you can make a funnel with paper or cardboard or sheet of plastic. ... and maybe duct tape...
Hope this helps!
Sep 10, 2009 | Ford F Cars & Trucks
How to fill a transmission on 2002 x type
Through the transmission dipstick tube, with a skinny long funnel(transmission funnels)Good luck and thanks for using FIX YA
Feb 01, 2009 | 2002 Jaguar X-Type
How to replace a dipstick funnel on a 2003 Audi A4
There's a metal bracket that the plastic tube clips to at the top. The 2 little tabs on each side clip it to the bracket. once u unclip it, it "should" pull straight up. The one I did yesterday broke into a bunch of pieces. I had to break it off and pry the last bit off with a prybar. the new one snaps right down on.
Oct 17, 2008 | 2003 Audi A4 Cabriolet
Toshiba Satellite A135-S4527 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
