Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Hose breakage The lower hose broke in half, which shot it's pickup ability. Is this a common problem? We've never done any crazy moves with it, just regular cleaning. Is there any prevention or do I need to shell out $20 regularly to replace the hose?
  • 7 more comments
  • Anonymous Nov 10, 2007
    Mine just broke - any idea what the part number is?
  • twinmama Dec 03, 2007
    Ours broke too after about 4 years. I noticed I had shampooed the whole run and only a drop was in the recovery tank! I hope I can fix it "easily"!
  • daytonsl Dec 06, 2007
    We had the same problem! we have only had the machine a little over a year and it has hardly been used. The uptake hose just broke right in half. I have no idea how that would happen. It seems to be a material defect. I can't even get a replacement hose as they are all out of stock and on back order. Hmmmm. Maybe others are having the same problem!
  • twinmama Dec 16, 2007
    I found the hose! It's at Oregoncityvacuum.com. Look under " Agility short inner hose. Hoover number 90001080". I ordered mine a few weeks ago and it was a few dollars cheaper... but it came within a week!
    Let's hope I can put it back and it'll actually work! I read other reviews of other cleaners, and it seemed best to just fix this one.
  • AAAA Dec 27, 2007
    The same thing happened to me last week. The inner hose does not have enough "extra" play so if you bend the handle down too low to reach under a dresser or bed the lower inner plastic hose snaps. I brought mine in to be repaired since it's under warranty. I did a long exhaustive search and came across this websitehttps://www.mdappliance.com that has Hoover Agility replacement hoses and their prices are the best I have found so far. The smaller inner hose (part number 90001080) is only $9.99 (compared to $13.99 & $19.99) and the external hose attachment (part number 91001004) is only $25.99 (compared to $39.95). I specifically asked and the parts are brand new... not refurbished or used. Their phone number is 866-914-1252. Just in case you're wondering, I'm not a rep for the company nor do I have any affiliation with them. I just placed an order for the hose attacment and came across this webpage and figured I'd add my 2 cents. Hope this info is helpful. I tried to make it as complete as possible.
    Goiod luck.
    PS: They also offer a flat rate shipping fee of $7.95 regardless of what you order. No sales tax unles you're in Ohio. :)
    and
  • teeteeteetee Feb 21, 2008
    UGH I emptied a whole tank of solution only to find that the hose had broken and hadn't sucked up any of it...How do you repair it once you get the new part?????
  • Anonymous Sep 15, 2008
    I had the same problem, the lower hose broke and does not **** up anything. I guess i have to shell out $20.00 for a new hose.
  • cleandude Dec 20, 2008
    Same problem.  Seems to be a theme with this model.  Not hard to replace- took me about 15 minutes toget to it and remove the split hose, but at $25 a hose to replace, mine will be at the curb withthe next split hose
  • Anonymous Feb 07, 2009
    Found the hose that was split - no problem purchasing a replacement. Big problem trying to get the cleaner apart to replace this hose. Emailed Hoover about this problem - no reply what-so-ever! My husband & I both tried to get the cleaner apart with no luck. My husband is a mechanic & has no problem fixing things - this made him frustrated & he finally took the cleaner & threw it in the trash! I feel that Hoover made this design flaw so you either have to pay them to fix it or purchase a new one. I can tell you I will not be purchasing another Hoover!
The same thing happened to me last week. The inner hose does not have enough "extra" play so if you bend the handle down too low to reach under a dresser or bed the lower inner plastic hose snaps. I brought mine in to be repaired since it's under warranty. I did a long exhaustive search and came across this websiteHose breakage - 1.gif https://www.mdappliance.com that has Hoover Agility replacement hoses and their prices are the best I have found so far. The smaller inner hose (part number 90001080) is only $9.99 (compared to $13.99 & $19.99) and the external hose attachment (part number 91001004) is only $25.99 (compared to $39.95). I specifically asked and the parts are brand new... not refurbished or used. Their phone1.gif number is 866-914-1252. Just in case you're wondering, I'm not a rep for the company nor do I have any affiliation with them. I just placed an order for the hose attacment and came across this webpage1.gif and figured I'd add my 2 cents. Hope this info is helpful. I tried to make it as complete as possible.
Goiod luck.
42e436e.jpganHose breakage - e1e69b4.jpg"http://i.fixya.net/uploads/images/e1e69b4.jpg" alt="e1e69b4.jpg" class="h_mi" />
Posted on Dec 27, 2007
  • AAAA Jan 19, 2009
    Any authorized Hoover repair place can order the hose for you and it should cost no more than $13.00 ($9.00 is their cost).
    To replace the hose remove all the screws. Beware that some are nicely hidden in the nooks and crannies. Don't forget to remove the screws from the top handle as well as the screws holding down the black exhaust vent. If while removing the screws you notice a small spring pop out don't fret. It came from the setting behind the round Hoover button that is used to lower the handle. Just pop it back into place. Once all the screws are removed keep them in a safe place and label where each one came from. Sorry for ending that sentence in a preposition.
    For the most part all the screws are the same type and size. After they are removed take off the top handle. Then separate the two halves of the center peice. Use a wire cutter to snip the top and bottom tabs of the broken hose. After the tabs are snipped it will slide off easily. Do not try and pry the broken hose loose or you may break the parts it connects to.
    After the hose is remove slide in place the new hose. It will snap into the little tabs on the connectors. Then carefully put everything back in place and replace the screws. Ta-da you're done.
    How to prevent this from happening in the future:
    The reason the hose splits is because Hoover did not make it long enough to tolerate the handle being lowered to reach under beds, etc. It is impossible to steam clean with the handle in the upright position (unless you use the external hose attachement) with 1 exception. I came to this solution after having replaced 3 hoses and swore I was not gonna let this machine get the better of me.
    There is a very simple way to lower the handle minimally and still get sufficient leverage to push the cleaner and sufficient force to press it against the floor so it sucks up the water without breaking the hose and without having to lower the handle more than just a tiny bit. This is what you do.
    Using your foot press down on the handle release button and minimally lower the handle. Lower it enough to placa a small throw pillow or stuffed animal between the handle and the base unit. Then steam clean as you normally would. The stuffed animal or throw pillow will change the angle of the unit so you can easily move it back and forth. When pushing the cleaner forward the water will get sucked up. When moving it backwards the handle does not need to be lowered any further and so the hose is not subject to strain or breaking. Just make sure you don't cover the exhaust vent and your hose will last.
The easiest way to fix the problem is to buy a roll of self sealing silicone tape. About $7 at most hardware stores. Take the body of the vacuum apart by removing all screws, including the four underneath on the round plate that holds the two top parts together. Remove the lower return hose by gently prying it off with a flat blade screwdriver. Be careful to turn the screwdriver sideways, like you're driving a screw. You don't have to turn it much, as the plastic nub that holds the hose on is pretty low profile. I was able to wiggle it off with minimal effort. Dry the hose off, clean it, then start wrapping the silicon tape around the hose from one end to the other. Start up on the plastic fitting so you get a good seal. Go all the way to the other plastic fitting, then keep wrapping all the way back to the other end. Stretch the tape as you go. Reinstall, and you're ready to go in half an hour plus the time it takes to find the tape. Works great.
Otherwise, go to Hoover.com and order part #90001080, pay $10 plus $5 shipping and wait a week.
Good luck
Posted on Mar 26, 2009
  • 625 Answers
The only thing I can figure is that something weakened the composite that the hose is made of. there's a complete hoover site [thehooverstore] that lists your machine with an exploded diagram. check it out.
Posted on Sep 22, 2007
    Problem Solver:
  • 6 Answers
I found the part at http://www.hooverpartstore.net/hoagstpa.html, cost me 14 $ and 5 $ for shipping. Was quite easy to change it .
But the failure of the lower hose looks like a bad design as it tends to break when you pull the upper handle closer toward the floor.
Another reason could be due to heat the hose expands and breaks when the upper handle is pulled back.
However if this is taken care of by the manufacturer , will be great product to use!!!
Posted on Dec 24, 2007
To anyone that is looking to get to the upper hose connection, all I can tell you is to keep looking for more screws to remove. I finally found all of them and have it apart now. You can do it, just be on the search for screws,
Posted on Jan 19, 2009
    New Friend:
Add one more to the statistics, as the same thing happened to mine. I'll think twice before purchasing another Hoover. (Hoover, are you listening???) The thing was lightly used; it shouldn't have broken this soon. What a cheap POS. Shame on Hoover! I'm going to check if the local Starks has the part, as I don't want to wait a week for it to ship, and I don't want to pay $10 for 1-2 day delivery.
Posted on May 20, 2010
    New Friend:
I know this sounds crazy - Silicone tape is a great idea, and would be my first move - but would you believe hot glue for a temporary fix? Removed the lower hose after much handle splitting struggle / removing lower and unscrewing upper / lower hard plastic intake and exhaust components. Softened the hose slightly with a hair dryer, to allow it to flex fully. Hit the split with a generous amount of med temp glue from a hot glue gun, a little at a time - didn't melt the hose plastic - and made sure to cool the hot glue with the "no heat" setting on the dryer before moving onto the next 1/2" section. Reinstalled the hose with the previously split end at the top, inside the handle, and unsplit end near the suction plate. Screwed it back together, ran great. Not convinced I'll be doing this again - will likely buy another hose and coat with silicone tape. That's a smart move.
Posted on Jan 24, 2010
I used duct tape to fix mine. So far so good - I've used it once since the fix. It's a pain to duct tape since I wasn't able to disassemble the vacuum.
Posted on Mar 19, 2008
SOURCE:
Hoover steam vac hose is broken
This applies to Hoover SteamVac model F5899-910.
My unit had a broken hose. I repaired the hose using duct tape and Teflon tape. The breakage seems to be due to a manufacturing error or design defect. The hose is clamped to the unit where it passes to the inside. The position of the clamp did not allow enough slack when the handle is released and the unit is wide open.
The hose coupling has a plastic latch that holds it onto the vacuum nipple. Pry it and remove the coupling. Then trim the ragged end of the hose and clean things up. Wrap the hose with some teflon tape and then tape the hose to the coupling with several turns of duct tape. Attach the hose coupling back onto the vacuum nipple.
Now you should move the clamp say an inch, so that it leaves more slack. Take the two screws out of the clamp and pry out the plastic bracket/cover that holds the clamp in place. Then move the clamp and screw the clamp back onto the bracket/cover. Then snap the bracket/cover back in place.
Take care not to put too much slack in the hose (by moving the clamp too far), as the hose can also bunch up due to being too crowded when the handle is upright.
Inspect the hose and the tape whenever you use it.
Aug 03, 2012 | Hoover F5899-910 SteamVac Vacuum
MIELE Silver moon turns off after about 10 minutes of using. If I press the "+" button on the handle, it'll turn on again and start up again. Is this an overheat thing or a hose thing?
That sounds like a hose issue, but to make sure it's not an overheat issue I would recommend ensuring that the hose, wand, and dirt tube through the power-head are all clear and free of obstruction. Also try raising the height adjust on your power head: if you have it set too low, air can't move through the carpeting and therefore it will overheat the motor and also not clean as effectively as it could. If all of these things check out, you will have to replace the hose with an SES-125A, but once you've done this you will not have the issue again. Cheers! -R
Aug 03, 2011 | Miele s558 Silver Moon Vacuum
I have a Dyson Animal DC28 and the wand won't pull out. This has just happened out of the blue - I was using it with no trouble up to now. I pull up and it just gets stuck. Any help would be...
I'm sorry to hear you're having difficulties with your DC28 Animal. From what you've described, it sounds as though the hose may have been twisted the last time you replaced the wand on the machine. This is easy to resolve by following these steps:
  • Extend the wand upwards as far as possible
  • With the rear of the cleaner facing you, follow the hose down to where it attaches to the cleaner
  • Whilst stretching the loose section of hose away from the cleaner, pull the hose release tab to detach the base of the hose from the cleaner
  • Allow the hose to untwist itself
You should now be able to pull the wand out to it's fullest extent, removing it from the cleaner. Once you've done this, simply reattach the lower end of the hose to the cleaner.
If you have any further questions, or if you'd prefer someone to talk you through this process, you can call us free on 1866MYDYSON.
Kind regards,
Jack
Dyson Online Customer Support
Jun 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do I change the setting on the capture bagless vacuum from hose to floor?
-Pull out your hose from the hose port, and it should be ready to go. If it is not sucking, then perhaps you have an obstruction in you hose. On the back of the cleaner where the hose attaches, you can squeeze the two tabs and the hose will release and you can check it for clogs. One easy way to tell, run the machine with the hose plugged in the hose port. Listen to the sound then take out the hose and listen. If there is a sound of release of air that is significant, then you have a clog in your lower duct hose(the hose that comes out of the lower half of the vacuum. You can usually remove this type of blockage from the underneath where the roller brush is, fairly easily. If it is in your hose, then you can try shaking it out. Sometimes you can see the clog and remove it easily. I am not sure if this was your problem I think maybe it is because there is not anything special to use the hose attachment.
Nov 12, 2009 | Eureka 12 Amp Capture Vacuum Upright...
Hoover agility steamer lower hose broken
Your right there is nothing you really can do . Enginering was very poorly thought out. Sorry . Wish i could do more . Ed.
Jun 18, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
DOES NOT VACUUM NOW
Several possible problems:
1) Did you clean the blue lower pickup container (dirty water) before putting it away?
Take out the pickup container and open it up, check the filter (under the little blue piece on top) and also open up the container itself and clean under the flapper on the "screen".
2) Look inside the housing and check the vac hose that goes from the front of the unit up to the rubber grommet where it goes into the lower pickup container. Is it clogged? If yes, take off the front pickup (the part the runs along the floor in front of the rotating brushes) and run a very narrow lint pickup brush (like for cleaning dryer vents) and clean out the hose. It works great.
3) Check the front pickup for clogs and clean
4) If you are trying to pick up water, make sure the setting is set to wet. If you are trying to use it as a vacuum, set it to dry.
Hope this helps.
Nov 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover agility--poor suction, still!
When you remove the dirty water tank, on the machine, there is a screen that gets clogged and will prevent good suction, is this one clean? If it is, do you feel suction at that screen, if so then there is a problem with the tank. If no suction there, then you will have to check it over for a air leak or a bad seal.
Apr 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Agility, No Suction!!!
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Oct 04, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
5,031 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
