Question about Dell Latitude D600 Notebook
Will over heating cause the computer to freeze?
Trying to eliminate concerns for a Dell Lattitude d610 that freezes up after 45 minutes of use. No viruses found. No pattern of software identified. Laptop is often left on for aim messages and will freeze.
Focusing concern on a failing cpu fan or heatsing fan, anybody have a view on this solution?
CF
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    Overheated Processors will shut your system down abruptly, not freeze or cause your OS to hang.
  • 39 Answers
Run Memtest 86 (which can be run from a booted from a CD as well as floppy) and if you run into errors, replace your RAM.  If you have more than one stick, make sure to run Memtest separately on both sticks.  You also want to make sure your Hard Drive doesn't have bad sectors.  Run scandisk for that.
Posted on Apr 21, 2009
  • 326 Answers
D610's are almost always over-heating due to simple dust build-up. Our fleet needed to be cleaned out on a regular basis. Simply grab a can of compressed air at a office-supply store, or related, and aim it straight into the bottom fan, and back vents.
Unless you have squealing or your fan is not spinning at proper speed, or at all, your parts are fine and a simple remove of dust and debris should work.
If this does not solve your issue, please let us know. If this information was helpful, please take a moment to rate this solution. Thank you.
  • NitrusInc
    NitrusInc Apr 22, 2009
    What was the result of cleaning out the dust?
  • NitrusInc
    NitrusInc Apr 24, 2009
    Hello. Have you had the chance to remove any dust or debris? What was the result?
Dell inspiron D610 fan wont turn on
New cpu heatsinks use water in sealed tubing, and can cool for a long while. Idling computer may not need more cooling.
Mar 15, 2012 | Dell Lattitude D610
Plugged it in to a wall outlet, turned on the computer, the microsoft screen scene appeared, the jingle played, then it turned itself off and won't turn back on.
Unassemble the battery and after 5 minutes reassemble it, then plug it in another wall outlet and when the charging light turn on, turn on the notebook.
Jul 21, 2011 | Dell Lattitude D610
My Dell Latitude D610 is overheating and freezing and some times when it is booting the fan takes time before it starts rotating
This issue may due to over heating and can be fixed by replacing FAN and heat transfer solution.
Better you need to contact hardware support person to do this task.
Thanks,
Satheesh
Jan 11, 2011 | Dell Computers & Internet
My dell lattitude d610's fn key are not working
Have you already tried pressing Fn + Numlock?
And I know it's obvious but rebooting the computer?
Sep 29, 2010 | Dell Latitude D610 Notebook
How can i recovered bios password of dell d610
Take out battery don´t work on Dell Laptops.
I got my Dell Bios & HDD Master Pasword within a few minutes from http://www.bios-password.kickme.to/
Jul 30, 2010 | Dell Latitude D600 Notebook
My Dell D610 starts and operates properly, but completely locks up after about 10-15 minutes. I let it cool, and it will start again. I have checked and the fan does run. I cleaned the area around the fan...
you can download this to see if it is getting really hot first.
http://www.diefer.de/software/i8kfangui31.exe
after you install it you can go into the settings and turn on the monitors for the cpu, gpu, ram, and sometimes the hard drive. you can turn on the fan monitors too to make sure they are working. you can control the fans as well. i use it on all my dell laptops. it its not freezing becuse of overheating then it might be the hard drive or you might need to reinstall windows
Apr 26, 2010 | Dell Latitude D610 Notebook
My Latitude D610 power flicks on off on off The
In my opinion, it sounds like a motherboard issue. The keyboard skips would indicate that the keyboard is not always getting the inofrmation to the CPU. If it freezes, it may be overheating.
Dec 14, 2009 | Dell Latitude D600 Notebook
HP Lattitude D600 Laptop freezes up
It could be a number of things. . Sometimes the unit will freeze when it overheats.. Have a look around the exhaust vents and see if there is excessive dust built up around there. If you notice any, you may have to take it in to get checked. If you are tech-saavy, then take it apart and clean out the CPU fan. Also make sure that there is good airflow around the vent when operating the unit.
If this is not the case, then you should take some notes to see if there is a trend when this happens. What sort of apps are running when it freezes at the 45 min mark. Is it only on battery? If so, its possible the battery is running out of juice and the software is not throwing the correct warnings - it just freezes the machine (this is exactly what my Asus EEEPC does to me when I let it run wayyy down on the battery - it freezes. However, it warns me a few minutes ahead of time). Try yours on AC and see if it has the same problem. If not, then its likely your battery. You may need to go in and tweak your power management settings to make sure that it warns you when the battery level is low.
Apr 20, 2009 | Dell Latitude D600 Notebook
DELL Lattitude D620 freezes
Check the dock, there might be a problem in the dock, you can also try insulating the edges of the dock with some tapes before docking and plugging the dell, sometimes a short spike of static can hang the computer. If all else fails, dell has a pretty good customer support, you can go contact them...
Dec 10, 2007 | Dell Latitude D620 Notebook
Dell Latitude D600 Notebook Logo
729 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
