Question about Samsung PN42A400 42 in. Plasma TV
I cannot adjust the volume on my Samsung 42" Plasma (PN42a400)
As a matter of fact, all of a sudden, I can't control anything on my TV. The only button that seems to work right now is the big power button on the front. I've unplugged the TV for several minutes and that didn't seem to fix it. I've taken the batteries out of the remote and tried using the controls on the side of the TV, that didn't work.
This TV is only 4 months old. It's under warranty, which is great, but it seems to me that this should be a fairly easy problem to fix.
  • 32 Answers
Its called a sleep timer. when it does come back on you need to find the sleep timer program ans turn it off
Posted on Jul 12, 2009
  • 41 Answers
The fact that it turns on is good. Most likely the trouble is with a data line internal in the set. It may be the remote receiver IC or a push button on the set. A stuck button or switch can confuse or load communication between internal microprocessor circuits. Take a look or feel each of the push buttons do they feel the same when pushed ? Do they have a slight snap when pushed. The tac switches used in most cases are made like a small old clicker. If one feels soft and has no snap it's probably your trouble. If so tap lightly around but not on the button and it might free itself. You should just have Samsung replace whatever is the cause.
Posted on Apr 21, 2009
La pantalla de mi tv esta en diaspositivas a que se debe eso
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 28, 2016 | Samsung PN42A400 42 in. Plasma TV
What is the problem with my Plasma tv, it has a black verical box with a yellow and blue line inside?
Contact the nearest authorized service center for Samsung. This is not a user repairable fault.
Aug 29, 2012 | Samsung PN42A400 42 in. Plasma TV
I have a 42" Samsung
This clacking and clicking noise could have been coming from a capacitor going bad in the tv. If this is the case where the tv will not turn back on, I would suggest calling samsung to try to get a replacement or get the tv serviced. Trying to replace bad capacitors can be a tedious job and requires knowledge of soldering small components. This may also void your warranty if you still have coverage.
Aug 19, 2011 | Samsung PN42A400 42 in. Plasma TV
SAMSUNG PN42A400C2D 2008 model In the past 3 months tv has started turning the volume all the way up & down by itself. Sometimes it stays at the highest level and sometimes it does not. I can...
most probably a leaking electrolytic capacitor in the system control section, or the system Integrated Circuit chip itself needs replacement, have it checked by your friendly neighborhood (qualified) technician. Hope this helps ;-)
Feb 03, 2011 | Samsung PN42A400 42 in. Plasma TV
Samsung plasma tv pn42a400c2dxza. when i try to turn it on it starts making clicking sound than it starts buzzing. i unpluged everything from the power supply and the buzzing sound stopped. but when i plug...
This problems is the power supply board is causes and the problems.Try website like Ebay.com buy a whole refurbish power supply board for the replacement,will solved this problems.
Nov 29, 2010 | Samsung PN42A400 42 in. Plasma TV
Samsung plasma tv white spots i have an extended warrenty and wonder if this is covered thank you
Hi tim
To answer your question;
The only thing that an extended warranty doesn`t usually cover is physical damage or abuse.
You problem is technical and therefore should be cover.
Hope this help Good luck
Jan 18, 2010 | Samsung PN42A400 42 in. Plasma TV
Samsung 42 inch plasma turns on and off buy its self
power supply board is failing. call1-800-samsung for nearest service center.
Nov 19, 2009 | Samsung PN42A400 42 in. Plasma TV
I want to display my digital photos on my TV can i do this and how
Does your tv have a pc input? if so you can save them to a laptop connect your laptop to your tv and display them that way.
Oct 18, 2009 | Samsung PN42A400 42 in. Plasma TV
How do you turn off closed captioning?
Go into the user menu and select "Setup" and find the CC slection and select "OFF".
Jul 12, 2009 | Samsung PN42A400 42 in. Plasma TV
My tv enlarges the picture cutting off peoples heads on the screen
First go to your source such as your Cable Box or Sat Box. The problem is that the Aspect ratio is set incorrectly on the source or the tv.
Jul 01, 2009 | Samsung PN42A400 42 in. Plasma TV
Samsung PN42A400 42 in. Plasma TV Logo
415 people viewed this question
Jerry Greenberg
Jerry Greenberg
