Question about Mtd Products Yard Machines 158CC Tiller
Tecumseh ohv130 engine wont start. It has spark,fuel,clean air filter, good battery,I have checked the valve clearance and set them to .004'', the plug sparks, the flywheel key is not sheared,the carb is clean, fuel is fresh. The thing just wont start. what is it about Tecumseh engines that makes them so finikey?
Replace the carburetor. It is not fixable, even though you can buy a rebuild kit for it. Been there, done that-- had to learn the hard way. What?? I said to myself. I've been fixing these small engines (shade tree) for years, and we always could rebuild the carb and adjust for peak performance. I absolutely refused to believe that my "rebuild" didn't "fix" this carb. Hard to believe, but true. Replace the carburetor. This is your "something new" you've learned for today.
Posted on Sep 03, 2009
2 Suggested Answers
  • 45 Answers
SOURCE: Tecumseh ohv130 engine wont start. It has
does it have an oil sentry switch on it? and if it has a fuel primer bulb on the side of the carburator,make sure it's not cracked.
Posted on Apr 29, 2009
Does Kawasaki KLF 300 have a fuel filter
Clean nicely carburetor make good adjustment pull the choke and without a gas engine must be lit
Feb 15, 2015 | kawasaki Motorcycles
The starter turns the motor over very slowly, but motor will not start.
If the engine is turning over too slow, the engine will not start. Try either charging the battery first or attach a charger while starting. If it is still turning slow, the starter may be drawing too many amps and need to be replaced.
Feb 15, 2011 | Parks Optical 13.5hp Briggs And Stratton...
DIFFICULT TO START ENGINE FROM COLD - NO PROBLEM WHEN HOT.
Engine is difficult to start when cold
  1. Check the battery condition, battery state of charge and starter motor current draw. Replace the battery if marginal and the starter motor if the current draw is beyond specification.
  2. Check the battery cable condition. Clean the battery terminals and replace corroded or damaged cables.
  3. Check the fuel system for proper operation. A fuel pump with insufficient fuel pressure or clogged injectors should be replaced.
  4. Check the engine's tune-up status. Note the tune-up specifications and check for items such as severely worn spark plugs; adjust or replace as needed. On vehicles with manually adjusted valve clearances, check for tight valves and adjust to specification.
  5. Check for a failed coolant temperature sensor, and replace if out of specification.
  6. heck the operation of the engine management systems for fuel and ignition; repair or replace failed components as necessary.
Engine is difficult to start when hot
  1. Check the air filter and air intake system. Replace the air filter if it is dirty or contaminated. Check the fresh air intake system for restrictions or blockage.
  2. Check for loose or deteriorated engine grounds and clean, tighten or replace as needed.
  3. Check for needed maintenance. Inspect tune-up and service related items such as spark plugs and engine oil condition, and check the operation of the engine fuel and ignition management system.
Feb 12, 2011 | 1992 Suzuki Swift
Problem cranking first thing in the morning or colder days. Garage says battery and alternator look good. Sometimes it takes up to 5 minutes to start.
Nov 10, 2010 | 2002 Jeep Grand Cherokee
Peugeot 307 1.4 2002 does not start when engine is
Jul 23, 2010 | 2005 Peugeot 405
My 300M is having difficulty starting. Just pull up when the engine is cold, if I disconnect, I have to wait ten minutes to pick up again
Jun 15, 2010 | 2000 Chrysler 300M
Difficult starting when the engine is cold. Doesn't idle well
May 29, 2010 | 2005 Chevrolet Aveo
Tecumseh 17.5 hp ohv engine won't start
check valve clearance. if ok you going have change carb.sometimes i rebuild a carb everthing seam ok but carb wont work right so i have get a new carb and it works fine evertime
Jul 20, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Gv 250 wont stay running
read my solutions on this site for clogged carbs.....Tim
Jun 01, 2009 | 2002 Hyosung GV 250 Aquila
Mtd Products  Yard Machines  158CC Tiller Logo
1,262 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
