Question about SanDisk Sansa m250 MP3 Player
Mp3 c240 The mp3 is plugged in but there is no drive listed for it. The mp3 shows connected and battery is charging.
  • 8,596 Answers
Not vista compatible, not Mac compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Posted on Jul 06, 2008
SOURCE:
Can I use my Sandisk Sansa C240 while it is charging?
This is normal when the Sansa is connected to a computer. You can use it while charging if you connect it to something else. For example, you might have a cell phone with a USB charger that plugs into a wall outlet. You could connect the Sansa to it, and it would let you listen while charging.
May 01, 2010 | SanDisk Sansa c240 MP3 Player
My Sandisk sansa c240 will not show up on my
you will need to install the computer drives for that devise and also you will need to plug it in to the usb port of the computer
Aug 17, 2009 | SanDisk Sansa c240 MP3 Player
Not charging
Try connecting directly to USB port on your computer, NOT a hub. It needs power to charge.
Apr 29, 2009 | SanDisk Sansa c240 MP3 Player
How to I start the c240 up it My computer doesnt
On Windows XP, when you open My Computer, the Sansa C240 shows up at the bottom, under "Other". Because of DRM restrictions, you cannot copy media files to the C240 using Windows Explorer. You have to use Windows Media Player to sync playlists to the C240 (WinAmp can do it also).
I also suggest that you check out RockBox. It's an alternative operating system for portable media players and they have a version for the Sansa C240. It will give you some additional functionality.
As far as I can tell, to copy files to the microSD card (if you're using one) you have to use a media card reader, then insert the card into the C240.
Mar 17, 2009 | SanDisk Sansa c240 MP3 Player
My mp3 says that i don't have anymore space, but it only shows 10
I'm not sure what you are asking, but maybe my experience can help you. I was using Windows 2000 (it has no DRM) and the Sansa C240 was displayed in Windows Explorer like a removable drive. I could copy and delete files in Windows Explorer. I switched to Windows XP and when I connected the C240, no files were displayed for it in Windows Explorer. I realized that XP had DRM and all the media files had to be transfered with Windows Media Player. When I opened WMP, it recognized the C240, but it didn't list any of the mp3 files I had already loaded on the C240. WMP asked if I wanted to delete all the media currently on the C240, but I clicked No. After that, WMP worked like the old files didn't exist. It would only delete files that had been copied to the C240 when it was synced.
I would recommend that you use Windows Media Player (or WinAmp) to delete all old media files on the C240 and use the sync button to copy and delete files from the C240. See Windows Media Player help for details.
Mar 15, 2009 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa c240
The photo files that aren't showing up don't meet the specification in some way or another - they aren't jpeg, the resolution is wrong, or the file size is wrong. Transferring music files from card in mp3 player to computer may not be possible - connect mp3 player to computer, double-click my computer, and open photos folder or any other folder that looks relevant - see if the said photo files are in there. If not, then you are out of luck.
Jul 07, 2008 | SanDisk Sansa c240 MP3 Player
Files on my sansa c240.
Not Mac compatible - sorry; you will get the internal drive to show up, but the files may or may not show up; they may or may not transfer
Jul 05, 2008 | SanDisk Sansa c240 MP3 Player
My sandisk c240 charges when plugged in but fails to be recognized on the computer
There is quite possibly a problem with the USB cable or the USB port on the computer, but try this shortcut force to force the computer to recognize the Mp3 player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
Battery Charging
most sansa players will; not charge on a laptop. plug it into a desktop
Jan 06, 2008 | SanDisk Sansa c240 MP3 Player
How to charge battery
Connect it to your computer using the usb cable provided.
It should show that the battery is charging.
Dec 25, 2007 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
