Question about Kenmore 24 in. 15933 Built-in Dishwasher
Quick rinse led won't clear 2 dashes.
Can't clear this led on the quick rinse button for my kenmore dishwasher 665.15933000. any chance this is covered under manufacture warrenty, etc...? or should next step be to have repair come out to take a look? thanks! jason
  • jasonbullock Sep 21, 2007
    thank you for the advice. i purchased it in 2002 so its not under warranty. so i guess its on me.
  • 209 Answers
If the appliance is new enough to be covered by the guarantee (less than a year from new)anything that doesn't work right is covered, contact the manufacturer and tell then the problem and that you cant get it to work how it should, they will either call out and put it right or tell you how to reset the machine over the telephone do not work on appliances yourself when covered by guarantees
Posted on Sep 21, 2007
6ya staff
SOURCE:
Quick Rinse is flashing
Check the level of rinse sid box. Refer user manual for further user correctable tips.
Apr 11, 2010 | Kenmore 15634 Built-in Dishwasher
Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Quick Rinsw button blinking
I may have fixed my similar problem- I opened up the machine to get access to the control panel as tech17 advised- then in addition to disconnecting the mylar ribbon, I disconnected all the connections to the control panel.... keep in mind to ensure not to confuse any of the connectors you disconnect. Running a cycle at this time... seems as if working.. can't tell if water is running or just the motor- -- HA! -- i confirmed no water being pumped in.... We then found a float switch (Item 30 on schematic) that got loose from its casing on the front interior right lower side... we put that switch into its proper place and now ALL IS WELL!!!! Yippee!!!
Feb 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Dishwasher 665.15895793
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
Jan 12, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Flashing quick rinse light on panel
I had the same problem but I found someone wh said that there is a way to reset the dishwasher. I tried it and it has worked so far.
Here is what I did.
Oct 24, 2007 | Kenmore 15769 Built-in Dishwasher
Buttons don't respond
I have same model, same problem. The appliance repair person came today and said it was caused by a bad touch panel, which is one of the most expensive parts on the dishwasher - around $200 (plus the service call and labor = $340) and must be special ordered and will take about 2 weeks. Sorry. He said that this is a frequent problem on Kenmore dishwashers.
Dec 06, 2006 | Kenmore 16639 Built-in Dishwasher
Kenmore 24 in. 15933 Built-in Dishwasher Logo
78 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
