Question about Brother IntelliFax-2820 Laser Fax
Toner Low Light
I replaced the toner cartridge, but the toner low light will not go off. Is there a reset i can perform to get this to turn off? thanks in advance for any help.
  • Anonymous May 13, 2009
    low toner on display after new one installed
    Problem Solver:
  • 19 Answers
Make sure you pulled the seal out before you replaced toner,if you did not,do so.if you did i need to know if you purchased oem or generic replacement cartridge. check package instrutions on how to remove seal,or to see if cartridge even has seal.
Posted on Sep 22, 2007
How do I clean the rollers on dell 1720?
First of all dirty rollers are not the cause of your problem as long as the printer is picking up the paper.
Black marks or streaks on a DELL 1700 series printer are usually caused by the drum assembly which, in this model, is separate from the toner cartridge. There is no repair, you need to replace the drum assembly and perform the drum reset procedure. In very rare cases a buildup of residual toner on the fuser can cause marks as well, but I have never seen this on a DELL printer.
To replace the drum:
1. After removing the paper tray, open the front of the printer.
2. Remove the toner cartridge by pushing down on the black release tab and pulling the toner up and out of the printer.
3. Pull the drum assembly straight out of the printer using the blue plastic handle.
4. Carefully unpack the new assembly and install in the printer. Be careful not to touch the photo-sensitive roller underneath.
5. Reinstall the toner cartridge, close the printer and insert the paper tray.
6. Perform the drum reset procedure exactly as follows:
power off and open front door hold down the continue button as you power on printer leaving front door open when error light comes on release continue and close front door. toner low, load paper, ready, and continue will all be lit. press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change when just toner low is lit, press and hold continue button until lights cycle up and down in sequence. release continue.. toner low will be lit again turn printer off, wait 10 secs or so and then back on press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Aug 10, 2014 | Dell 1720dn Laser Printer
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
Brother 9460 reset toner
Like most laser printers, the toner light comes on early. This gives you time to order new toner. I find it best, since it does not stop the printer from printing, just to have a toner on hand and when your toner is empty replace it. Since this is a mesurement inside the toner cartridge its self, there is no way to reset the warning (other than replace the cartridge).
Feb 13, 2012 | Brother MFC9460CDN AllInOne Laser Printer
About Nashuatec Aficio SP 3200SF question
You could try going into the sp modes and check sp 5052-1 this is for independent toner check if the toner cartridge was checked by the copier as empty and you refilled it the machines check of the chip still senses it empty by turning this off it could reset it for you .. I have had some mixed results sometimes it works only occasional failure.. Hope it helps Good Luck A
Jul 03, 2009 | Ricoh Office Equipment & Supplies
Light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
May 21, 2009 | Samsung ML-2510 Laser Printer
Hp laser 4500 says toner is low or out even after new cartridge
There is a toner sensor in this printer that shoots a beam of light through the toner cartridge. As long as the toner is full and blocks the light, it sees it as being full. If it were the sensor, it would tell you this for all the toners, though. The printer also calculates how much toner may have been used and gives warnings based on that. It could be that this isn't getting reset after you change toner. You can reset the toner gage by going into the reset menu and selecting "New xxxx cartridge" and changing it to YES.
Mar 17, 2009 | HP Color LaserJet 4550n Printer
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
We re-filled the toner cartridge and re-installed it, but the red light indicating toner low keeps blinking, also the computor is telling us toner is low
Just refilling the cartridge may not resolve the low toner message. Many cartridges have a sensor chip that must be reset to clear the message. Due to this, many people opt to buy replacements or refurbished cartridges that have had the sensor chip reset.
Aug 15, 2008 | Computers & Internet
IBM infoprint 1312 toner and error light.
If both Lights are solid, it means that the top cover is still open and the toner is low. Please make sure the top cover is closed all the way. If the toner light is blinking and the errror light is solid, it means there is a toner cartridge error. Please try a new cartridge. If that solves the issue, then you should return the damaged one.
Mar 10, 2008 | IBM Infoprint 1312 Laser Printer
Low toner warning
Is this an after market toner cartridge? I've had bad ones straight out of the box. Have you replaced one before on this printer? Ray
Jun 21, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother IntelliFax-2820 Laser Fax Logo
775 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
