My cd rom drive is not reading any disk - Computers & Internet
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 40 Answers
Try to find out the status of device driver in
DEVICE MANAGER present in CONTROL PANNEL (WINDOWS VISTA)
if it does not show any error the there is surely hardware problem.
you can also try system restore to solve this problem and don't forget to shut down your system after system restore.
Posted on Apr 21, 2009
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
My imac dvd drive reads DVDs but ejects CDs and installation disc
The optical drive has separate hardware for reading CD-disks and for reading DVD-disks.
So, "half" of the drive has failed. Replace the drive, since that will be less-expensive than an attempt at a repair.
Jan 15, 2011 | Apple iMac HD, CD-ROM / DVD-ROM Carrier...
I cannot hear sound system play cds and videos
Every CD/DVD-ROM drive has an audio port opened. An audio cable connects to the back side of the CD/DVD-ROM and connects to the motherboard. Most MB's have two four pin audio ports, one slot white in color and a second black in color. As far as the CD/DVD-ROM not reading the disk. Make sure the disk is free from scratches; oils from you're fingers or just plain dust. Open the drawl and blow out the CD-ROM drive or buy a CD cleaner which will clean the internal laser. These days it’s hard to find a CD/DVD ROM drive with a warranty longer than 1 year. Most ppl buy a new one when it fails to read CD's.
Cheers'
Mike
Jun 19, 2010 | Intel Motherboard
CD ROM
The drive has NOT been able to read the directory of the disk you put in.
Possible causes:
Disk may be a DVD which your drive may not be able to read.
Disk may be a DL DVD (double layer) whcih your drive may not be able to read.
The disk might be a BluRay which your drive may not be able to read.
Your drive may be defective or have a dirty read head.
May 03, 2010 | Compaq (120192-B21) CD-ROM Drive
Problem when downloading file says installer integrity check has failed. common causes include incomplete download and damaged media. cannot install files.
If you're reading the file from a CD-ROM, then either:
* the CD-ROM drive is reading incorrectly,
* the CD-ROM is scratched, and thus cannot be read 100% correctly,
* bad RAM in your computer, that "corrupts" the data being read from the disk into the RAM.
Replace the CD-ROM.
Replace the CD disk.
Download "MEMTEST86+", and run it, to test the RAM; replace, if necessary.
Mar 26, 2010 | Computers & Internet
Trying to install XP when disk selection comes up it reads, "Unkown disk. There is not disk in this drive". NOt sure what that means.
your drive is not being read,
have you set BIOS to boot from CD ROM,
is your CD ROM working,
is your XP CD working
Do the following
1 go to BIOS and re-set to BOOT from CD ROM
2 use another copy of XP/Win98/Vista etc to verify if CR ROM is reading the CDs else...
if you doubt CD ROM drive has a problem....
3 use a USB external CD ROM, and to do that u need to re-set the BIOS to boot from USB CD ROM
Dec 07, 2009 | IO Magic Corporation GigaBank (I250HD35)...
My cd-rom won't read the disk that i am putting in.
If you have a can of air, blow it softly into the cd-rom to make sure dust isn't causing the laser to act weird. Then try a couple of different cd's to be sure and if the problem still exists, then the cd-rom is bad and it will have to be replaced.
Jan 29, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Sony combo drive
Can you please explain more the problem so i can help you? CD-R is the same as CD-ROM!!!! best regards AMINE
Aug 27, 2007 | Sony 52X32X52X16 CDRW DVD Combo Drive...
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
