Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Various Corrupt Messages on Blue Screen (wi...
By sizzler on Sep 21, 2007
I've been having problems with my pc for a few days now, with it trying to restart itself automatically and not being able to start at all sometimes.
I was getting a bluescreen for a split second, saying PFN_LIST_CORRUPT and a bunch of other stuff that I couldn't read as it just flashed on and off so quickly.
I was told that it could be a memory problem.
My motherboard is a Biostar M7NCG 400 and there were 3x sticks of 512Kb Ram in it. I removed the stick from DIMM Slot B2, Restarted the PC & it worked fine (showing 1Gb of RAM now instead of 1.5Gb). I defraged the pc & ran the following programs; RegscrubXP; AVG; CCleaner; Ad-aware & SpyBot S & D. It ran for approximately 12hours yesterday without restarting.
Today, I decided to swap the removed ram stick with the one in Slot B1 and again it worked fine.
I decided to try the other stick back in the B2 slot and on restart, had the same problems with restarting automatically etc.
I also saw a blue screen at various times over the last few days, saying something like IRQ, but again, it flashed on and off so quickly that I couldn't read it properly.
I'm suspecting it's a motherboard issue, but I'm no expert and I'm wondering if there is any way to test the motherboard to see what the problem actually is.
Other system details as follows;
CPU = AMD AnthlonXP 2400+
Power supply = 230v
Graphics = Nvidia Quadro4 700 XGL
1x CD ROM & 1x DVD-RW
2x HDD
1x Modem (not used)
Same Problem
Jun 13, 2008
-   Yeah, I have a simillar problem when installing 2GB of RAM. I've been using a memory consisting of 2x512MB Geil Value Pack, witch worked fine on my Abit AX8 mobo. But just a few days ago I decided to upgrade it to 2GB. Well, that's the problem: the pc crashes in Windows XP, when using 2 gigs. And it happens randomely, sometimes it works fine for a while, before receiving a stupid blue-screen error and than reboots. I've tryed multiple combinations of memory, all of witch sums up to 2GB. The mobo is fine phisically, and i guess my power source (450W) is enough. And every time I use just 1.5GB of RAM it works fine.
Just now, I installed 2x1GB of RAM (one made by Apacer and the other made by Kingmax ), placing them in the first and third slot (which in my mobo's manual means single channel data bus) and I haven't had a crash for an hour or so, which is quite a record.
So I'm asking: could there have been a problem runnig different memory modules (but all consisting of DDR400 memory) in dual channel ?-   Om_Bun
Apr 14, 2008
-   hi my borad was working fine, only for me to change upgrade frome 98 to xp pprofessionals which started showing me the blue page asking for technical information and hard disk is corrupt with virus etc what can i do-   monabella
Solution #1
posted on Jan 04, 2008
Not Rated)
carenet
Rank: Master
Rating: 90%, 3 votes
some ram may only fail at high temperature.
pls use 512mb of ram or an single chip and check ur pc.
Was this helpful?
Yes
No
Solution #2
posted on Sep 22, 2007
Not Rated)
TechWizard
Rank: Wiz
Rating: 78%, 166 votes
I have worked on several computers with simular problems.
First your ram. Are you making sure that the ram sticks all have the same speed? the other thing you might want to look in your manufacture technical books to see if you are using the right amount of ram for that specified slot. Many motherboards have maximum ram for each slot. Speed of your ram sticks is very important never mix them together. always use the same speed. Using varing speeds you could have a whole host of problems. I found that if you mix the speed of the ram sticks you can cause the registry , bios and even your IRQ settings to malfunction or make entries that cause your computer to fail. The other thing I see is you might want to up your PSU 230W for a AMD and the graphics card is quite low. I would recomend at least a 450w or even a 500w dual 12 volt rail. This will make sure that enough power is going to your motherboard and also to your graphics card.
Note: Using mixing speeds on your ram sticks over time can cause perminate damage.
When your PSU is under powered you can also have what i call creeping problems. What I mean by this is that as the PSU gets overloaded slowly things begin to malfunction eventually leading to a full shut of your PSU. I have only seen on a few overloaded PSU it damaging a componet on your motherboard. But once again it all depends on how it happened and what was the load when it occured. I hope this helps if you have a comment or more questions feel free to contact me.
Was this helpful?
Yes
No
Solution #3
Not Rated)
mistyman
Rank: Wiz
Rating: 83%, 356 votes
Hi, in my repair workshop I have seen this problem several times and almost always it is a problem with blown capacitors on the mobo.
When you have the case open again inspect the capacitors, [they are the round objects grouped together in lots of 5/6 on your bourd]
If any show signs of bulging at the top or leakage from the bottom, unfortunately its time to replace the mobo. This can be fixed but the labour cost will almost equal a new board. Goodluck mistyman
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
when im trying to install audio driver on win Xp it is giving Err:00002x
Answer
Hi As a layman in HTPC i had managed to build an HTPC searching on net. Please help me to install an... (More)
Answer
video output from internal videocard is shivering
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motherboards:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
