Question about Emerson EWF2703 27" TV
Fuse blows when it gets plugged in
The tv was not powering on at all and I tracked it down to a blown fuse. I replaced the fuse and when I plugged it in to the wall I saw the fuse blow again. Everything I have looked up tells me that it is probably a bad resistor. How can I find out what all the different resistors are suposed to test at. Or is there a likely resistor that it would be?
    Genius:
  • 1,153 Answers
No it doesn't sound like a resistor, it sounds like you have a short in power supply, you can look for bad Diodes in bridge rectifier,or solder bridge, or transistor short, start from beginning to end. It is definately a short and most of the time resistors open and this will not cause a blow just a dead set.
Posted on Sep 21, 2007
SOURCE:
Plug fuse blew.
Something is blowing the fuse if its out again, check for rails that are lower then they should be, chances are you will need a new power board.
Feb 08, 2018 | Televison & Video
PCM fuse keeps blowing
It's possible you ran the battery down, trying to start? Have to make sure battery has a full charge and battery connections all good. If battery is down, have to use a charger and get it charged, we can't test anything if battery is down.
I did look at power distribution wiring diagram for your vehicle, I found pcmB fuse--20 amp. Two fuse legs goes to pcm, the other goes to load side of fuel pump relay. If I had to guess, I'd say the fuel pump has a problem. If the wiring before the fuel pump relay or the pcm was the problem, then the fuse would blow as soon as soon as you plug it in. The fuse circuit shows to be hot all the time. Just my opinion. There might be other issues, but, I can't track it from where I am.
Aug 06, 2017 | 2005 GMC Yukon XL
I have a problem with the power supply board with my TV (Samsung LN46A750). I had a fuse blown and tried to replace it (with a like fuse, of course). Replacing that fuse and attaching the power cord let...
Power supply board have power surge parts,but not totally dead,it just giving to much power some where,that why it keep killing ur fuse.This problems,u must have great electronic skills to track it down.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Power surges are rarely happen,but the surge protector will stop massive power will go the protector when it happen instead all the power will go to the tv itself.
Mar 16, 2011 | Samsung Televison & Video
Recieving no power even though plugged into good outlet. is there a fuse?
Hello
Ofcourse there is a fuse in the AC track of every TV. But if fuse must blow, there must be some reson for that. Fuse is included in the path of AC as a protecion to the circuit for over voltage of over current. Just look inside, and confirm the fuse is blown or not. If blown, find out the reason for that and tectify it before placing an other fuse in place. Otherwise, the fuse you replaces will also blow out. OK.
Feb 17, 2011 | Hitachi 57F500 57" Rear Projection...
The power safety fuse was blown. I replaced it but everytime I plug the TV, it blows the fuse. It is a Sony projection HDTV
When fuse blows again and again that means power supply is bad and needs to be replaced.
Let me know exact model of your Sony TV to provide you power supply board part number info.
Nov 03, 2009 | Sony KP-51WS510 51" Rear Projection...
Will not power up, something popped yesterday, and it lost power and will not come on
The fuse might have blown. Could be various reasons. Unplug the TV. Place the TV down on it screen (on a SOFT FLAT, UN OBTRUSIVE surface). Remove the back panel screws and the panel. There will be a fuse, it is likely blown. Replace it with a fuse of the EXACT SAME amperage (it will be stamped on the fuse [example 5A is a 5 amp fuse]). Replace the back panel and carefully tighten all the screws. Replace your TV on it's stand. Plug it in, and turn it on with the remote. If it works, great. If the fuse blows again, you have a more serious problem. Do not attempt to fix it yourself, it could create a fire hazard. Seek a repair shop.
Sep 29, 2009 | Sanyo DP50747 50 in. Plasma TV
I had a power outage and now the tv will not power on. This is for a 55" Mitsubishi WS-55511. no green blinking lights.
You may have a blown fuse. Unplug the TV and remove the back. Look for a small fuse near where the power cord goes in.
If it is blown that may be the problem.
Use a magnifying glass to read the AMP rating.
replace the fuse and plug it in. If the fuse blows again you need expert repair services.
If the fuse doesn't blow then try to turn it on.
If it turns on then check the operation of the TV.
If the fuse blows again or the TV won't work correctly then you need expert repair service to fix your TV.
You may be able to have your household insurance pay if it is damaged by lightening or a power surge.
Lee
May 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Blown fuse
check mcm electronics, if the fuse keeps blowing you have bigger problems.
Sep 03, 2008 | iLO 3200 32 in. LCD Television
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Outside transformer blew, now TV doesn't work
I hope is only a fuse and it will not be hard to find it should be close to where the power cord goes in and it has to be replaced with the same amps and size.Make sure the set is not plug in whe you remove the lower back and once you replace it put the back cover on and plug it in,if more damage is present it will blow up again right away or it will blow up when you push the power button,I hope it doesn't but if it does you will need someone qualified to check the rest.Be careful
Sep 22, 2006 | Hitachi 46W500 46 in. TV/DVD Combo
Emerson EWF2703 27" TV Logo
104 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
