Campbell Hausfeld PW2102 Gas Pressure Washer Logo
A
Anonymous Posted on Oct 01, 2013
What oil do I use in a Campbell-Hausfield gas power washer 1750 PSI with a nTechmush 6.0 Hp motor
5 Related Answers
Anonymous
  • 211 Answers
  • Posted on Feb 14, 2009
SOURCE: Campbell hausfield power washer Model #pw175500le
Hi
First priming hte engine(put some gas in the plug hole)and start the engine for few times until the engine runs constantly.If not there is a fuel delivery problem.Check the air and fuel filters,the fuel line,the muffler and screen inside.Disassembly the carb,check and very carefully clean it with compresed air.
best regards savumihai71
Anonymous
  • 583 Answers
  • Posted on Sep 05, 2009
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Anonymous
  • 251 Answers
  • Posted on Nov 19, 2009
SOURCE: pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Anonymous
  • 88 Answers
  • Posted on Jan 25, 2010
SOURCE: Hausfield Campbell pressure washer 2300 psi .Water
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Mike Squire
  • 420 Answers
  • Posted on Jun 16, 2010
SOURCE: Gun
Replace the wand (Gun) The valve is not repairable.
Campbell Hausfield Electric Pressure Washer 1350 handle leaks
You are probably missing the washer or O-ring. Loosen and separate then check. It may also be a broken O-ring.
How much oil and gas mixture to use in 1800 psi 2.2 gpm washer where do i put in the oil
it is a 4 stroke motor so it just runs on neat unleaded fuel.
oil is in the engine and this should be 30w oil
3helpful
What type of oil is needed in my Durabuilt air compressor-6 gallon tank? I need to replace some oil. Thanx. Send response to "[email protected]." Thanx.
Howdy. It's actually called Compressor Oil and is available at nearly all hardware stores and tool rental agencies. There are several brands and they are all comparable. I use Senco, but Campbell Hausfield is also good. Farmerbear at FixYa.com
1helpful
Gun
1helpful
2answers
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
8helpful
2answers
3helpful
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 • Garden
1helpful
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Hi
Top Campbell Hausfeld Garden Experts
Jay Finke
Jay Finke
john h
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
