Question about Mitsubishi VS-4543 45" TV
Power problem powers up then goes off
  • 1 more comment
  • spacystacy Jun 10, 2008
    powers on and then goes off in about 2 seconds.
  • QRSTeeUV Oct 10, 2008
    When plugged in.... I turn television on then goes out in 2 to 3 seconds... before that started... I would see three lines dividing the picture on my screen , one line was red, blue and yellow... what do you think I should do to correct my problem
  • Anonymous Feb 18, 2009
    powers on for 2-3 seconds shuts down
Listen carefully, if you turn on and it goes off after 2 seconds, you need to change f902 and check q05a00 for short, if shorted, replace it, and then check for 130v and 34 v on transformer, if they are present, your problem has been solved, if you turn on the tv and hears little clicks, replace the optocoupler of the power supply. i did it and got my tv back on again!!!!
Posted on Jan 08, 2010
Check for opens at convergence ic's, if none replace stk391-020e's with new lead free sanyo drivers or just trouble shoot them.
Posted on Oct 14, 2008
    Genius:
  • 1,153 Answers
Look in Mitsubishi threads here your problem has already been answered.
Posted on Sep 21, 2007
Where is the power steering hose? on a 2001 pontiac montana
The power steering hose,goes down under the power steering pump,it goes directly down from the pump,and cuts under the engine to the rack and pinion,both hoses do.If this was helpful,please rate,thank you.
Jul 11, 2010 | 2001 Pontiac Montana
When I press power, light blinks for about 15-20 minutes, then goes off. Press power again, on solid for 30 seconds, then goes off. Press power again, TV finally comes on.
Your television is in need of repair. Hard to tell what exactly needs to be repaired but when the power light blinks in that way then this is the TV's way to tell you it needs to be serviced.
Apr 25, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
Power light comes on and then goes off.
power light comes on and then goes off
Dec 08, 2009 | Acer Aspire 3680 Laptop
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Red light on,press power on grenn light goes on
Have the main power supply checked out first, you only have standby 5v power supply working right now.
Oct 30, 2009 | ViewSonic N3752w 37 in. LCD TV
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
I have a denon avr amp it powers up then goes in
disconnect all connections cycle power if the power stays on reconnect equipment one at a time cycling power after each peice reconnected. If the power goes back to stand by with nothing connected the reciever needs repair
Jul 18, 2009 | Denon AVR 2808Ci Receiver
Power goes on and then clicking noise in back and power goes off. jvc hd rear projection
this sounds like a power source problem! also the flyback converter on the circut board could be bad!
Dec 10, 2008 | Televison & Video
Televison & Video Logo
274 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
