Question about Kenmore 22422 Top Load Washer
Wahser wont run spin cycle.
My washer wont run the spin cycle. however if I lift the lid and close it again it will start the spin cycle. what is the problem??
  • mpgemp Apr 24, 2009
    washer will fill up but agitation will not begin. earlier, i could drop the lid down again and it would start but now even doing that does not work...
Door switch is probably bad or connection is loose. Remove the top cover to gain access to the switch.
David Le
Posted on May 05, 2009
Kenmore washer mdl#110.23832100 spin cycle motor
Hello, looks like your lid switch is on it's way out, replace it...you will find it normally about half way down under the lid. If not there you will find it in the control panel on the right side next to the water level control. The reason it works some times and not others is because some times it fails to push the lid switch down far enough to engage. the lid switch is a safety divice inteneded to stop you opening the lid while in a high speed spin. If you have any other questions please feel free to comment again. Mike
Oct 01, 2009 | Washing Machines
Washer will drain but won't spin
check your lid switch, make sure it is open and close properly..you have very strange problem never run in one like that...for more info please contact me directly at totalcarefl@yahoo.com
Sep 07, 2009 | Kenmore Washing Machines
Washer does not spin. What's wrong with the machine??
Sounds like a bad lid switch. If it works intermittently, could be loose. When you close the lid, the two parts of the lid switch line up which allows continuation of operation. You can bypass the lid switch by removing power to machine; locate the switch FOR THE LID ON THE MACHINE SIDE, remove the two wires and wire nut them together. MACHINE WILL RUN NORMALLY EVEN WITH THE LID OPEN.
Jul 02, 2009 | Washing Machines
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore 92274800 repair ... WONT SPIN
My 110.92274800 did the same thing 1hr ago. Ive isolated the Problem it is a 15.49 cent problem from the manufacturer's website Part # 285753A. I am going to order and try and tackle the problem myself unless i can find it at a local Appliance Center that has it on Monday. Will keep you informed. Doesn't look to Hard. if you lean your Washer forward you will probably find 1/8 inch white peg looking plastic pieces. assuming you can hear the motor running on the spin cycle. You may lean the unit forward put it on spin and look at the motor to make sure it is still in operation. Hope this helps
Jan 03, 2009 | Kenmore Washing Machines
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Kenmore 22422 Top Load Washer Logo
173 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
