Question about Mtd Garden
Replacing an extension spring Yard Machine Model 675 riding mower
Need advice on replacing an extension spring a Yard Machine Model 675 riding mower. One man trying to pull the spring and guide it on the anchor. . .can't see the anchor while pulling the spring.
SOURCE: Yard Man 46" tractor mower driver belt
I had one belt come off and not sure of the positioning of the belts
Posted on May 01, 2010
  • 53 Answers
SOURCE: how do I change the blades on a mtd yard-man 42" riding mower
u do not have to remove the deck. all u need is a floor jack and some air pressure because the bolts may be very tight u will needs either a 7/8 or 13/16 socket and they come off normal lefty loose righty tight. good luck
Posted on Jul 08, 2009
  • 3600 Answers
SOURCE: Yard Man 21" Mower Pull Cord Won't Retract
You will find the retractable spring is broken you can go to any lawn mower shop and buy a replace me, also Wal mart and others you will have to wind it up till rope is tight then hook to the flywheel where the slot is. cost about $10.00 also lube the center hub bearing with wd 40
Posted on Jul 16, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
  • 6 Answers
SOURCE: cant find my model number on my mtd yard machine
Hi, it should be under the seat. but if it is a engine part you will need the engine make and serial number
Posted on Oct 24, 2009
Manual for a briggs and straton riding lawnmower model #13ac762f755
Do you need the manual for the machine or for the engine? Your model number comes back to a MTD Yard Man mower.
You can go to Briggs' website after you get the serial and model of the engine, for a manual on the engine.
If you need particulars for the mower - follow the link. Yard Man Riding Mower 13AC762F755
Apr 14, 2017 | Briggs Garden
Where does the idler spring go on a yard machine model 13An772G
need more numbers... you only gave partial model number
Sep 11, 2014 | Mtd Garden
38 in deck murray riding mower. Apparently a spring broke from under the deck. I'm not sure what it is for. I found the spring in my front yard. So I was able to continue mowing. I mowed my whole back...
Its probably from a tensioner pulley. If you take pics and post along with make, model and serial number I could look up specs to see where its missing from. To answer your question, no it shouldn't hurt anything. But, everything is on your unit for a reason, you may throw a belt or something. Hope this helped!
Sep 12, 2013 | Garden
Yard machine riding lawn mower won't crank over
You might want to refer to this Yard Machine Riding Mower Manual for troubleshooting techniques.
Feb 02, 2013 | Garden
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Jun 08, 2010 | Mtd Garden
Cant find my model number on my mtd yard machine riding mower and i need a replacement part. it is a rear engine 8 hp 30'' cut
Oct 23, 2009 | Garden
MTD yard machine model 668 (46in) does not engage
check your brake pins on the trany there rusted and sticking. you can also shoot some wd-40 and hit your bake pedal till ti comes loss. now if you still can't use low dear check your variable speed pulley assay. may need to be replaced or rusted too. check for missing spring too. adjustment may be needed
Sep 26, 2009 | Mtd Garden
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Where to connect spring for clutch?
Go to sears parts.com type in your model and you may be able to see there.
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
858 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
