Question about Dryers
My front loading gas dryer has stopped putting out heat
  • 716 Answers
If possible pop open the case and see if its lighting if it is and then goes out its your thermostat if it doesn't light at all its the igniter. In most cases its the thermostat not detecting the heat and shutting the gas off to prevent explosion. Let me know if you need help.
Sincerely,
Michael Scott
Posted on Apr 21, 2009
I have an LG front load dryer and it has stopped heating. Do you have any suggestions?
Because you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice.
Jul 26, 2011 | LG DLG5988 Gas Dryer
My front load dryer stop drying with heat all it does is air dry what would be causing that problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 08, 2011 | Dryers
My dryer runs fine, just wont heat, was working fine this morning, but on my second load of the day it stopped heating, cleaned all the lint from front-even pulled out and cleaned the lint from the back...
heatman101
Apr 30, 2011 | Bosch Nexxt 500 Dryer
My dryer has stopped heating completely. Worked fine for six years and stopped heating four days ago.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 06, 2010 | Frigidaire FLEB8200DS Top Load Stacked...
I have a front loading large capacity kenmore dryer about 6 yrs old. All of a sudden it has stopped heating. To Heatman from Hartman
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Dryers
Lg dryer stop heating after i stuffed it witha blanket front load gas dryer Tromm 3 years old. I completely cleaned it, but still won't heat I can fix it with your help
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | LG DLE2514 Electric Dryer
Gas dryer runs but no heat
Hi
Thanks for using FixYa. Please check the things that could stop a gas dryer from heating:
- Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor, timer, selector switch, sensor.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | LG WM-2277HW Front Load Washer
Dryer not heating up
Hi, If the dryer stops heating later in the cycle, it is most likely the coils on top of the gas valve. It is a very common issue with the gas dryer.
Here is how to change the coils
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jul 21, 2009 | Roper RGX4634KQ Gas Dryer
No heat in dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
98uit
Feb 05, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
Dryers Logo
41 people viewed this question
Top Dryers Experts
