Question about Acer AC 713 17" CRT Monitor
Monitor problem The monitor's menu gets displayed automatically and the contrast increases continuously. Even if i try to exit the menu, it continues to increase. Sometimes, its not possible even to exit the menu. Its causing me terrible problems. not allowing me to work on it. Hoping for a positive resolution.
  • Anonymous Aug 19, 2008
    Same problem -continuous showing menu display-after that complete monitor became dark.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
You will have to take it to tech as there is a possibility it is loose from inside or print loose inside. if it is ok then you will have to check circuit connected to menu control ckt or control itself is defective. hope this will help.
Posted on Oct 01, 2007
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Dec 24, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Desktop is continuing to display contrast as 100
Dear mahendra
Welcome to Fixya Customer support
This is common problem observed in many monitors compaq,HP,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor botton circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.It deffinately solves your problem.
Good Luck
Fixya Customer Support
Chandrashekhar
Jul 22, 2009 | IBM E54 15" CRT Monitor
Monitor continuously displays the menu option
click on the monitor menu button and change settings after save and exit.
Jul 09, 2009 | HP mx705 17" CRT Monitor
Monitor problem
It seems that ur control panel on the monitor having some problem...U need to take it to service center....
Dec 02, 2008 | Computers & Internet
Contrast automatically increases to 100%
yes! The same problem in my monitor. The contrast of my PC monitor increases automatically to 100%.If I try to reduce it,it increases again.
Oct 19, 2008 | IBM E54 15" CRT Monitor
Onscreen Display is always ON
usually this is controlled from a small separate board you can find them on ebay for about 20 dollars.
Jun 22, 2008 | Samsung 793S 17" CRT Monitor
Acer AC 713 17" CRT Monitor Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
