Question about HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 paper jam
Recently, I have been having the same problem crop up each time I try to print/copy anything on my PSP 2355. The machine pulls in a sheet of paper on request but instead of printing in normal manner, but instead of stopping as if to print at top/beginning of sheet, the sheet continues about half way through the machine, then stops. Error message 'Paper jam. Press OK to continue.' appears but there is no jam. Removing sheet of paper & returning it to tray doesn't help; same thing happens each time.
  • 10 more comments
  • saltybone Nov 24, 2007
    I have the same problem..andI tried checking and cleaning the rollers on the back of the cover..and the same error paper jam' comes up half way through..then when I press OK the paper goes through and the whole process repeat until I cancel.
    Some people says it may be dust on the 'sticky' feed roller or maybe 'sensor' ..if so, they didn't tell me what to do..all they suggest is buy a new printer! Can you offer more help, please? Thanks
  • LukVdH Nov 30, 2007
    Tried cleaning feed-rollers. Doesn't help. I also think it must be a broken paper-sensor. No HP spare parts can be bought it seems ?
  • Cazza18 Apr 02, 2008
    I have this exact same problem and I'm a poor stdent! How can I fix it without it costing me a fortune?
  • Dave_Herts May 26, 2008
    I was given one of these, as it has this exact fault. I have cleaned all the rollers, checked the back door etc, and the fault still remains. Has anyone else managed to find a fix?
    i have exactly the same problem on a 2355 i was given.Anyone found a fix?
  • graadpa9829 May 28, 2008
    i bought this piece of junk and have had nothing but trouble with it=lost the receipt so im screwed==same thing paper jam=tried everything=cant get any results from hp= if this is the way they they do business ill never buy another thang from them=and will certinelly tell everone i know
  • Anonymous Aug 07, 2008
    Keeps feeding & then states paper jam.Keeps repeating .No joy .No good
    with Apple Leopard anyway.A bit of disaster since Leopard installed but still  was partially useable . Now its going to be replaced .
  • t_perreira Oct 22, 2008
    the roller for the paper feed is out of he printer i want to know whee to put it back
  • Sukki Nov 06, 2008
    I do have the same problem... but I believe it is as someone else already stated ... there is a small plastic piece that is VERY easy to break off, and it is causing the paper to go through unevenly and giving the error. I can hear something (small loose) rattling when I jiggle it even slightly. The parts are just not durable enough. One misfeed that is a little off-center, and it's no good any longer.
  • Anonymous Nov 07, 2008
    paper jam
  • Anonymous Feb 06, 2009
    yup - the same little plastic latch t at the left of the print heads (right of the paper rollers) was broken off - should be fine when reattached, just got to find a way of repairing that'll cope with the use..
  • cih14 Apr 27, 2009
    hp psc2355 paper on self test goes in comes half way back out nothing printed and says paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Posted on Apr 19, 2008
    Scholar:
  • 132 Answers
These printers always wind up jamming/stalling if the back door is the tiniest bit off. Take off the back door and reapply it, even though it looks OK. See if this is of any help: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&product=421997&lang=en&docname=c00265823
Posted on Sep 21, 2007
    New Friend:
Try this for the HP 2355
empty the paper tray
print something
You will get "Out of Paper" error
press OK
insert a blank sheet within about 3 seconds
It will pull in the sheet and print
submitted by rpwiener
This is only a fix but not a repair!
Posted on Oct 05, 2011
    New Friend:
Hi, can any one take a picture of the piece that you glued?
I have the same problem, i can see that is broken, but it misses something.
Regards.
Posted on Apr 29, 2010
2 Suggested Answers
SOURCE:
sandrew
  • 2961 Answers
SOURCE: HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Posted on Jun 24, 2007
I keep getting the message cartridge jam on my hp psc 2355. A paper jam was pulled out of the front so I know this is the cause but how do I fix it please?
It's not saying carTridge jam, it's saying CARRIAGE jam. Something is stuck under the heads.
unplug the power from the unit, and try to manually move the heads off to the left side, checking for paper under the head as you move it over.
Check the head docking area on the right as well.
Plug the unit back in and everything should be fine once everything is cleaned out.
May 24, 2011 | HP PSC 2355 All-In-One InkJet Printer
Hi, Is there any way of clearing a paper jam when the paper is completely inside and out of reach?! The machine just tries to clear it but nothing happens! It a piece of glossy photo paper and won't catch.
just open the cover the printe head will come to center disconnect the power cord and remove the catridge and then roll the roller manually and pull the paper out.
Jan 25, 2010 | HP PSC 2355 All-In-One InkJet Printer
Cannot print - keep getting paper jam message - after pressing cancel button, paper keeps feeding into machine w/ paper jam message again
Hi
try cleaning the paper jam first
check out the following link,this should help you a great deal
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=us&lc=en&dlc=en&product=422000
Jul 14, 2009 | HP PSC 2355 All-In-One InkJet Printer
My HP PSC 2355 tells me there is a paper jam
Request you to get it check with the engineer personally or their might be a piece of paper stucked somewhere in the corner. I tried the same and was fixed
Jul 02, 2009 | HP PSC 2355 All-In-One InkJet Printer
Repeat warning
Have you tried removing/re-inserting the ink cartridges??
May 16, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 won't feed photo paper
You can't use the photo papers in this kind of printers
Aug 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
Hp 2355 all in one
Does the same message come up when you try to copy?
Oct 28, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP PSP 2355
Jun 24, 2007 | HP PSC 2355 All-In-One InkJet Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
4,737 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
