Question about Zefal Paragon Hybrid Bicyle Fender Set
Back sprocket will not adjust down to easiest gear.
    Scholar:
  • 34 Answers
Below is an online video on how to adjust your gears. Your issue could be a number of things:
- cable is seized or full of gunk- make sure that it is cleaned out and lubed before you try to adjust your deraileur.
- check the two lockout screws on the deraileur - one handles the high and other handles the low gear. Their purpose is to make sure the chain doent fall into the spokes as well as the frame when reaching the extreme ends of the shift.
http://bicycletutor.com/adjust-rear-derailleur/
Posted on Apr 22, 2009
How to keep my gears from slipping
Firstly ensure the derailleur is in good condition and not bent so the chain is running perfectly in line with the sprockets. Ensure the stop screws limiting the extent of the travel of the derailleur are set correctly to prevent travel beyond the first and last sprocket.
A badly worn chain could need shortening or replacing in order to provide the correct chain tension or a loose chain could be a matter of a derailleur that hasn't seen the oil can for a while and is not tensioning the chain correctly.
If the bike has been involved in an accident the rear forks could perhaps need some adjustment so a straight edge laid alongside the main chain-wheel coincides approximately with the middle of the rear sprocket cluster.
At this stage it is also wise to ensure the gear cable is in A1 condition, smooth operating and properly oiled with no internal frayed strands causing problems.
If your gear selectors are of the modern style with detents the gear cable needs adjusting so the centre of each detent at the gear selector positions the derailleur precisely below the selected sprocket. Once this is done if everything else mentioned above is ok the gears should now operate smoothly and positively.
If adjustment doesn't work then the problem is likely to be with the basic requirements above.
Jan 26, 2015 | Cycling
Qc 10 00a
First gear on both sides would result in the easiest gear possible.
Lets think of it like this....
Left hand in the "1" gear, you now have gears 1-7 to use on the right hand side. The right hand controls the rear gears and brake.
Once you reach gear number 7 and want to find #8, move the left hand to gear number 2. Now set the right hand back to #1. This is your 8th gear.
You essentially have 3 sets of 7 gears, with each set being harder then the previous.
Clear?
Apr 26, 2014 | Shimano Cycling
When shutting down throttle in gear, a heavy clonk is felt through transmission! chain and sprockets good.! thankyou.
If the chain and sprockets are in good condition and adjusted properly ( 1 1/2" slack ), you should check the rear wheel sprocket dampers. These are made of rubber and can deteriorate over time. If the dampers are bad you will be able to move the rear sprocket forward and back while the bike is sitting still. It is an easy fix to replace them, just remove the rear wheel and sprocket. they are model specific parts and should be available from your local dealer.
Steve
Jan 02, 2011 | 1993 Honda CBR 1000 F
How to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
May 03, 2010 | Cycling
I replaced the sprocket and gear assembly on my
Here are some things to check.
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Jan 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Trek 6500 Shimano deraileur adjustment issues
Derailleur adjustment takes time to master. Try this out:
First, wash your drive train out really thoroughly and use a degreaser (Simple Green works really well) and a chain brush on the derailleur and chain. Rinse it off and let it dry, then relubricate the chain (and ONLY the chain - never lubricate your derailleur). Now flip your bike onto the bars and saddle so you can crank while you shift manually. Use the middle chainring up front to adjust the rear gears. Okay, shift into your highest gear in the back and then release the derailleur cable. Use this opportunity to make certain your "H" setting is good; the derailleur's jockey wheel should be perfectly aligned over the small cog. Now manually push the derailleur to the lowest gear (while pedaling) and set the "L" so the jockey wheel is immediately outside the last cog. crank back to the high gear. Turn the barrel adjuster for the cable tension to its half-way point (figured by unscrewing it all the way and then counting revolutions as you screw it back in). Pull the cable taut and reattach it. Shift into your middle gear (or if it is an even number of gears, pick one of the two middle gears). Use the barrel adjuster to get the jockey wheel exactly over the correct cog. Pedal and shift through the gears. In each gear, back-pedal to make sure the chain is not skipping. You should be able to free-wheel without problem in every gear on a properly adjusted drive train. If the gears are requiring much adjustment on the barrel adjuster, then you may have a bent derailleur hanger. This can be straightened manually without tools if you have a good eye and patience. If it goe that far, come back and repost "bent derailleur hanger".
i hope this helps
-matthew
Oct 28, 2009 | Cycling
How do I operate 10 speed road bike?Schwinn La Tour How do I change gears
the gear lever on the left controls the front derailleur which will have two different size sprockets...when you first start to ride you want it on the smaller of the two. The gear lever on the right controls the back or rear derailleur with a gear cluster of five small to increasing larger sprockets...when first starting to ride you want that on the largest one .....five in the rear and two in the front (5x2=10 variable speeds to chose from). as you increase speed slowly lift up (because this lever will be located down) on the right shifter to help maintain an even speed to help you go faster..when your on the smallest gear in the back and want to go even faster then pull down on the left shifter to go to the larger sprocket you are now in ten gear.When coming to a stop reverse the shift levers and repeat...if the chain rides off the sprockets when shifting especially in the front derailleur it means the shift guide is bent to far to one side or you derailleur needs adjusting same goes for the rear..there are two little screws stops with springs that you use to make these fine adjustments. My family owned a Schwinn shop, i was a mechanic for a good 12 years and i havent heard the name La tour in a long time i owned one myself and have a traveler still today. Tip..keep chain lubed, WD-40 will work fine, and also lube the gear cables with a light grease...also dont rotate the handle bars up for easier comfort because in an emergency stop situation all your weight will transfer to the brake levers and you fly forward over the handle bars.
Oct 02, 2009 | Cycling
It will only travel down a short distance then reverse
With the door in the open position loosen the chain enough so that you can remove it from the sprocket above the motor. Now run the motor until the sprocket has turned counterclockwise and stopped. With the door still open and everything attached replace the chain on the sprocket and tighten. Do not overtighten. This will get everything back into sync and some adjustments of the up and down limits may be necessary. Be sure to set that down pressure control back where it was as it affects the safety of the opener.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Replaced sprocket and worm gear on chamberlain 1/2 opener
The easiest way to fix this would be to take the chain off the sproket with the door and the trolley in the down position. Next hit the wall button and pay attn. to weather the gear is turning clockwise, you want it to turn that direction, wait until the unit stops by itself, next put the chain back on and now you should be able to adjust the limits. otherwise you should call a local professional. They will usually service your door as well as fix your opener.
Feb 15, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Zefal Paragon Hybrid Bicyle Fender Set  Logo
122 people viewed this question
Top Zefal Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Zefal Cycling Expert? Answer questions, earn points and help others
