Question about Samsung HL-P6163W 61" TV
Samsung 60" TV
TV will not light up. Lamp has been replaced as well as the ballast. Still all three lights on front flash a regular pattern.
  • sobeit Sep 24, 2007
    I have looked for a bad fuse and the thermostat is good. There is a ticking sound inside the set before shutdown but the lamp does not light up.
  • Anonymous Dec 04, 2007
    new bulg no fix i guess new ballest and we will see
    Genius:
  • 1,153 Answers
Probably bad caps on board, also fuses go when lamps go out sometimes, you can look for a fuse also.
Posted on Sep 21, 2007
SOURCE:
Samsung DLP not turning on
usually the colorwheel will prevent the set from powering up when all three lights blink. Diagnosis assistance is available for free from www.tvrepairworld.com
Jun 15, 2012 | Samsung HL-S5086W 50" HDTV
My samsung hlr6167w will not power up. It sounds as though the lamp is trying to strike, however it never does come up on a picture. After several minutes, all three lights on the front power cirle (Lamp,...
All three LED lights flashes,u hear alot of clicking sounds too?Yes,ur tv the Ballast board is dead too.This Ballast board job is only to ignite the tv projection lamp only.Replace the Ballast board,should solve this problems.
Apr 17, 2011 | Samsung HL-R6167W 61" HDTV
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you [email protected]
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
Aug 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Why don't my tv show a picture but all three light are flashing
samsung tv have a problem with color wheel,lamp,ballast.
Oct 05, 2009 | Samsung HLT-5075S Television
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung hln5065 picture issue
If all 3 lights are blinking on Samsung DLP it means your lamp is burnt out or has issues. The manual says replace the lamp when all 3 lights are blinking. If you can hear the arc from the ballast the lamp should light if the lamp is operational.A new lamp should solve your problem.
Mar 01, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
Samsung HL-P6163W 61" TV Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
