Question about Refrigerators
Recently moved to a bush block with no mains power. Fridge starts and runs fine on 3 KVa generator. All attempts to run from 1000W(cont.)/2000W(surge) pure sine wave inverter unsuccessful. System successfully runs other loads up to 1000W including starting an older bar fridge with nominal power of 188W. Attempts to start Whirlpool, with nominal power of 100W and no other loads on system, causes inverter to trip on overload. This seems to indicate a starting current of about 20 times running current which is way above any other device I have come across. Typically 5-7 times. Is there some unusual feature of the Whirlpool that could be causing this?
  • dra22004 Apr 21, 2009
    Is there any information available on starting currents that would allow me to specify a suitable inverter?
    Whirlpool 270 Litre Model WR1(?)27SG
    Rated Input 100W
    Defrost Input 147W
    Energy Rating 400KWh p.a. (4star)
    Purchased 1 May 2008
  • 15,935 Answers
Please use the "continue with this expert" selection and post the make/model # so i can attempt to find the information.
Thanks!!
Posted on Apr 21, 2009
  • 11,896 Answers
Usually relays are same size but might be different on whirlpool. Whirlpool is unique in all it's features including compressor and power supply voltage and and usage. They are designed a liitle different than the others.
What is the general specification of Genset 20kv?
Generally 20 Kva power generator can produce more power. The voltage used in this 20 kva generator is 3 phase with frequency 50 Hz. 20 kva generator engine is already very enough for use on buildings that require large electrical power or public places such as shops. According to me HARGEN provides the best high quality genset.
To fill the fuel tank to the full required 62 liters of fuel in order to use this 20 kva generator engine with more leverage.
20 kva generator engine is also issued a noise that can reach 61.7 db or can be heard up to a distance of 7 meters away from where this generator is located.
Sep 11, 2017 | Cars & Trucks
Hi. I have a generator. Kholer. Once i load the voltage. Its shuting downg the it showing over voltage.
what you haven't mentioned is the capacity of the genset
( 500 kva , 1000 kva etc ) and the loads that you are applying ( fridge , tools lights stoves , etc) comment on this for a better answer
Oct 19, 2015 | Electrical Supplies
Generator had been running for 3 hours with a/c and refrigerator and lights (on concession trailer)when we experienced a loss
the unit has gone into over load
The total power requirement has exceed the output of the generator
for example if the generator is a 2.500 kw or kva then it will generate well at 1.8 kva or kw but it will not run forever at 2.5 kva -kw
When a ac is running the power requirement will be constant on the generator and with the fridge as well then the load will be at the maximum out put of the unit.
when the fridge starts again the extra load will exceed the max out put of the generator and it will slow down ( lights dimming ) and eventually go into overload mode
have an accredited electrician calculate your maximum load requirement for an external power supply and then get a unit that is at least 15.. kva kw better that required
generally fridges use 1000watts , ac conditions will draw over 3000watts and any thing else adds up . I am guessing that your generator is only 2500 unit
Apr 12, 2015 | Northstar Electrical Supplies
Have a newage stamford alternator c20a kva 15.625 bolted to a deutz model f2l912 engine and have tried to pull the 2 components apart but can only get the 2 parts about 1 inch apart anybody got the an
from what you are describing the generator is a 15 kva unit bolted to the back of a deutz engine
check the end of the alternator armature for a bolt head. it is possible that there is a long bolt going through the centre of the armature shaft and holding the armature to the crankshaft on a taper
some older units used 4 rubber blocks in the drive from the crank shaft and there is a plate to retain them in place ( They were a safety device to protect the unit from damage if the mains power come back on while the generator was running. The out of phasing would stop the armature and rip the rubber blocks up)
Dec 30, 2014 | Cars & Trucks
Indesit Washing Machines
27 KVA is a huge generator and should work just as well as the grid. The only thing I can think of is the startup current, which can easily be 5 times the running current is playing havoc.
You might try tightening up all your lugs and screws in your panel. A loose neutral can create some truly weird problems.
Oct 29, 2013 | Indesit Washing Machines
I have a Yanmar 4.5 KVA Generator running into a Trace 2.5 KVA inverter/charger, the inverter requires 205-220volts to operate,once the inverter connects the voltage drops on the genny over a ten second+-...
try adjusting the gen voltage at no load to run at 240 volts
when the load comes on it will drop back to 220-235 volts
check the load output from the inverter as 2.5 kv is nearly 80% of the genset duty cycle
4.5 KV is start up KV and the duty KV is around 3..8 kv not the plated 4.5 kv
to get constant 4.5 kv you will need a 5.5-6 kv unit
if the current draw from the inverter is excessive , the engine may not have enough in reserve to over come the load and will not pick up the rpms
take the gen set and the inverter to a shop that has a calibrated load bank to test accurate power output to determine if the engine needs an overhaul
May 28, 2017 | Electrical Supplies
I would like to know if my Honda 2kva generator will run my air con dometic roof top B3000
I dont think so as this will be too much for the generator which has only 2 KVA as capacity.
Though the rated power is 2 KVA it will be safe to use it only upto about 1.6KVA.
The AC will require a lot of current on start up than in running and so it might no be good to have it strained.
Sep 26, 2010 | Dometic Rooftop RV Air Conditioner
What size compressor can I run
You would need 10 times the watts it takes to run electric air compressor,the start up takes a lot more amps to get it going ,then it will level off to the amps,what ever they are.That is the problem,getting it to power up,then it is fine,so you are looking at about 8000 watt gen.
Jun 13, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Kirby G3A Attempts to start but wont run
I would take it in to a vacuum service center. I had a similar issue and they restored the Kirby back to new for $100, it's been running fine now for 2 years!
Apr 13, 2010 | Kirby Generation 3 Bagged Upright Vacuum
How many watts would you get from a generator rated at 11hp and 5.8 kva. thanks
kva = kilo-volt-amps
watts = volts x amps = va
Therefore, 5.8kva = 5800 watts
Mar 24, 2010 | Honda 3000 Watt Portable Generator
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
