Question about George Foreman G5 Indoor Grill
My G5 Grill will not turn on
I accidently preheated my grill without the plates. Now it will not turn on and heat. I must have blown a fuse or trip a relay but cannot find how to reset it.
  • 4 Answers
The thermal fuse has melted due to being turned on without the plates fitted, the manufacturer does not supply these as a spare part, your solution is either bypass it or replace the unit, the fust is under the bottom plate inside a heat protective heat cover one of the wires.
Posted on Apr 09, 2010
    President:
  • 1,489 Answers
I'm not sure, but there is probably a thermal fuse which has blown. These are very difficult to acquire and sometimes very difficult to install (they can't be soldered -- you have to use a crimp connector).
The fuse is about the size of small glass fuse and has a wire on either end of it and it's connected in line with the hot wire coming from the wall outlet.
Posted on Apr 21, 2009
No heat
Check if you soldered it correctly, if not, the relay might have been damaged, you might need a new one
Jun 25, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Smeg electric oven model sa22xmf/7 not heating at all after power turned off
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 29, 2011 | Smeg Ovens
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
I HAVE A JENN-AIR SVE47600 GRILL-RANGE/W SELF CLEANINGCONVENTIONAL AND CONVECTION OVEN--ALL THE DISPLAYS ON THE FRONT LIGHT UP BUT WHEN I TRY TO PUT THE OVEN ON IT TELLS ME THAT THE OVEN IS PREHEATING AND...
I am suspect that the elements stay completely cold, but if they do, the elements have failed.
If the elements get slightly warm, then one of the breakers of the two breakers that power the oven, or, one of the fuses if a fuse box, has tripped.
If a breaker has tripped or fuse has blown, chances are one of the two elements has a short.
Jan 20, 2009 | Kitchen Ranges
Whirlpool AKZ451 oven not working properly
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Thanks.
Dec 12, 2008 | Whirlpool AKZ159IX Oven
EOU6330 grill doesn't heat-up all the time.
hi Step 1: Check the power cord, the plug, and the outlet. Then look for blown fuses or tripped circuit breakers at the main entrance panel or at a separate panel.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale thank u................
Sep 11, 2008 | Electrolux EOU6330 Electric Double Oven
George foreman 10814
The 240 degrees celcius Thermal fuse under the heat proof sleave as blown ...
60pence each from Maplins ...
Aug 26, 2008 | George Foreman 10814 Indoor Grill
Oven not heating up
circular element round the fan has blown. take back panel off inside oven and you will see element. to replace, take rear outside panel off and usually element is held in by 2 7mm nuts on posts sticking out of the element base plate. easy job.
disconnect of course
Jul 11, 2008 | Zanussi ZBF260 Electric Single Oven
George Foreman G5 Indoor Grill Logo
573 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
