Question about LG VX8300 Cellular Phone
Display backlight problem
Hi. My main display backlight suddenly went off as i was looking at my pics. I did not change any settings. The front display is lit as usual. I tried taking out the battery, restarting, recharging, changing display settings back and forth - nothing works :(. any ideas?
I have the same problem, i thought it completely blacked out, but i realized it was just the main backlight. i can see it if i hold a flashlight to it, but i tried everything to fix it, and ive had no luck.
Posted on Jun 24, 2008
SOURCE:
30" apple cinema display suddenly went blank.
It's probably the backlight. If you look very closely, perhaps using a flashlight, you might be able to see that it is still working but just not being lit up from the back. In that case it may be worth fixing, but if not, then it's probably past its useful life.
One other thing you might try is a different power supply.
Feb 14, 2014 | Apple Cinema HD 30" LCD Monitor
How do i change the time on my verizon ravine 2 from military time to 24 hour time?
Hi Marilyn - As military time is the same as 24 hour time, did you mean you'd prefer to display 12 hour time rather than 24 hour time?
The phone's manual explains how to alter the clock format so I've copied the relevant part for you.
DISPLAY SETTINGS (page123 of manual)
EASY SET-UP
To set up display options using the Easy Set-up Wizard:
1. Press the Center Select Key [MENU], select Settings & Tools and press the Center Select Key [OK]. Select Display Settings, press the Center Select Key [OK], select Easy Set-upthen press the Center Select Key [OK].
2. Select the display settings including the PERSONAL BANNER, DISPLAY BACKLIGHT, KEYPAD BACKLIGHT, MAIN WALLPAPER, DISPLAY THEMES, MENU LAYOUT, DIAL FONTS, MAIN CLOCK FORMAT, FRONT CLOCK FORMAT, and press the Center Select Key [SET].
To skip the step, press the Right Soft Key D [Skip].
MANUAL FOR CASIO RAVINE
http://nec-casio-mobile.com/support/download/GzOneRavine2_Manual.pdf
VERIZON FORUM TOPIC - CASIO RAVINE CLOCK
Casio zOne Ravine 2 Support
Dec 20, 2013 | Creative Labs ZEN V Plus MP3 Player
The backlight of my Nokia 1280 suddenly went off. Have checked the display setting and it's on normal, how do I get it fixed? Thanks
Download the nokia 1280 all hardware repair solution.
This solution pack covers the following problems on Nokia 1280 :
charger not supported solution
charging solution, jumper ways guide
keypad jumper ways
LCD display backlight LED solution
LCD display jumpers ways
LCD display ways
mic problem jumper solution
No network signal solution
power on-off key Jumper ways
sim card jumper ways2 guide
you can find the download at
http://www.megaupload.com/?d=ZM42W4W7
Have A Great Day.
http://www.pdxcellservices.com
free phones with contract plans or upgrades
Mar 30, 2011 | Nokia 1280 Cell Phone
Front display poising backlight and goes dim.
I believe this is most likely due to incorrect voltages at the display. If you have a meter and are familiar with working on electronics, check the voltage at pin 3 of cn501. It should be -28.5. If the voltage is very low, try changing C123 and C124 in the power supply. If the voltage is ok, check R925 and R932, these are both 10 ohm 1/8th watt.
Dec 13, 2017 | Aiwa AV-D97 Receiver
Hi! On my DSR-1800, the display in the upper lefthand part of the front panel has suddenly gone black! The machine works otherwise. I have disconnected the cables inside and sprayed with an electronics...
There are a number of possibilities here:
1) Power to the display is missing (check the power suppy and the pins of the display itself for poor/broken solder connections).
2) Display driver IC defective
3) Main CPU not sending info to display IC.
Were there any other symptoms prior to the display stopping? If not, check for the connections at the display itself first and update this with the results. I'll look up the service manual in the meantime to check for other posibilities.
Dan
Nov 03, 2009 | Sony DSR-1800 DV/Mini DV VCR
Gateway 22 inch LCD monitor suddenly goes black...blue on light works but pic only stays on for 3 secs when computer is turned on.
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway FPD2275W LCD Monitor
Cant change my sanyo 6650 mobiles incoming msg font
here i hope this helps you Display Settings
Changing the Text Greeting
The text greeting can be up to 15 characters and is displayed
on your phone’s screen in standby mode. You may choose to
keep the phone’s default greeting (“Sprint”), or you may enter
your own custom greeting.
To display or change your greeting:
1. Select > Settings > Display > Greeting > Custom.
2. Enter a custom greeting using your keypad and press .
(See “Entering Text”on page 39.) (To erase the existing
greeting one character at a time, press .
To erase the entire greeting, press and hold .)
Changing the BacklightTime Length
The backlight setting lets you select how long the display
screen and keypad remain backlit after any keypress is made.
To change the Main LCD or Sub LCD backlight setting:
1. Select > Settings > Display > Backlight.
2. Select Main LCDor Sub LCD.
3. Select Always On, Dim Only, or a preset length of time.
To change the Keypad backlight setting:
1. Select >Settings>Display>Backlight>Key.
2. Select Always Off or a preset length of time.
Note: Long backlight settings affect the battery’s talk and standby
times.
Note: The Always On setting returns to the previous value the next
time you turn on the phone.
Your Phone’s
Please rate this solution thanks...
Jan 30, 2009 | Sanyo Katana II (SCP-6650) Cellular Phone
The wired keyboard backlight turnes off too quickly
You would need to go into the Setting Menu and find the Backlight or Power setting to lengthen the display and keypad backlight times. Just know that your battery life will decrease the higher the settings especially since it is a VGA screen.
Dec 18, 2008 | HTC Touch Pro Smartphone
Main display went black on enV
Yeah same with mine... the front screen went black.... it started to get lines up and down... then all of a sudden just the front screen turned off! :-(
Jun 02, 2008 | LG enV VX9900 Cellular Phone
Display
A really dim display like you're describing is most likely a backlight problem.  If your inverter went bad you wouldn't have any display at all.  you need to get your backlight changed.
Oct 10, 2007 | Acer Aspire 5002WLMi Notebook
LG VX8300 Cellular Phone Logo
259 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
