Question about Whirlpool Duet GHW9150P Front Load Washer
Water leaking from the door and front panel of my Duet washer
Started about 5 months ago as water from under the machine, now has progressed to leaking at the side of the door (where the hinge is) as well as the bottom of the door.Also leaks like a sieve from the seam at the front panel just above the pedistal. HELP!!!!!!!!!!!!!!
    Problem Solver:
  • 5 Answers
Check the rubber door seal, sounds like its split which is common after 2-3 years use.
You can find the general area of the leak by placing dry newspaper on a dry floor beneath the machine.
Posted on Apr 22, 2009
My duet front load washer is licking water in front left side have any idea and how do u take off the bottom front cover
there are three screws under the front of the panel. make sure its not leaking from the door and running that way. if the bellow or door seal is damaged or bent or torn it will leak. please dont forget to rate me thanks
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirl Pool Duet Sport WFW8300SW00 leaks water from the detergent drawer after about 30 seconds of water running...please help!!
the water pressure is to high turn the tap down and wind the front feet right up. very common the water comes in to fast and splashes over the tray & down the front panel that will rust. replaced over 100 front panels still under warranty due to this problem.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I just noticed a large pool of water under the duet washer. it is not coming from the supply lines- It only appears when the washer is running. I see it leaking down the side (just above the pedestal). ...
door boot/gasket is bad replace and problem solved.but first take the front panel below door off and make sure before you buy a door boot but if it is leaking you can tell by wipeing finger below door while running usually.
Nov 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water has started pouring out from under my washer
Hello, you've indicated this problem only arrises during the rinse cycle, is that correct ? The leak doesn't occur during the wash cycle initial fill level ? I want to distinguish the difference because there has been a repair tip issued by whirlpool for the duet and sport washer's. This may be applicable to your machine. If it is indeed only during the rinse, the problem is within the door assembly. Specifically the glass and it's "seat" to the frame. Let me know, I'll watch for your reply. macmarkus :)
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool duet sport front load washer is fairly new (2008) now it has started dripping water during the cycle under the front of the machine. any suggestions would be helpfull.thank you
check tub boot for any tears in lip that seals to door zippers etc. can tear this.also sometimes water can leak from pump cleanout.you would need to remove bottom panel to check this
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet. I had washed 8 towels 2
To get inside the machine for a look, you have to take the back panel off,
1. Pull the plug
2. Turn off and then Disconnect the HOT and COLD water hoses at the machine
3. Remove bottom, side and all but 2 top corner screws from the back panel (all around the outer edges only) then supporting the panel, remove one corner screw, let the panel down on that side, then remove the other.
4.Remove panel
5. Grab a light, look inside.
My guess is that the spinning, wobbling drum worre a hose thru.
Good Luck!
Hint: Put all the back panel screws in loose, all the way around... then tighten them
Mar 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking in on the left side of the washer on bottom
you can remve the lower acess panel (3 screws along teh bottome front panel) too look to see where it coming from. the top also removes with 3 screws along the top of back panel
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer leaking during clean washer cycle
the highest water fill cycle for your waher is the clean cycle.it will fill up with 2x the normal amount of water in this cycle than any other.look for a cut or wrinkle in your door boot(grey rubber outer ring that seals between door and boot)if you find one,only fix would be to replace door boot.also clean inner door glass that comes in contact with door boot ring,any hard water build up or sediment(dog,cat or human hair)will break the seal and allow it to leak.good luck
Sep 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking from bottom back..
sounds like you need to check your back drain could be the drain is clogged.Fill with water and see if it comes from the drain
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
549 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
