Question about Dishwashers
AEG dishwasher pump runs continuously when power is connected regardless of whether the machine switch is on or off or whther the door is open or closed.
  • 15,935 Answers
You have not included your model # with your question so i can only give you general things to try/replace when a dishwasher will not turn off.
1. The Timer or cylce selector for your dishwasher is defective - not turning off the pump when the cycle is over.
2. (most likely) Leak detect solonoid tripped or failed - There is a tray beneath the washer which catches any leaks.There is a float-switch in the tray which runs the pump continuously to empty the machine if a leak is detected.
3. the float is stuck in the "over filled" position or possible a bad float switch, if the float is stuck in the up or full position, the d/w will not fill with water and the drain motor will often run all the time.
For a more specific answer - you will need to use the "continue with this expert" option and reply with the Model Number and the 9-digit Product Number Code (PNC).
These can be found on the rating plate of your appliance.
Thanks for using FixYa!!
Posted on Apr 21, 2009
My AEG F55402Vi0P dishwasher pump runs continuously, whether is switched on or off, or whether is open or close. Please advise.
I likely has a flood proof circuit in the bottom. It is sensing water in the bottom pan an has gone into pump out thinking it is leaking. Check for water under the dishwasher in the pan bellow. If there is you will have to find where it is leaking from.
Dec 07, 2016 | Dishwashers
AEG 40850 - pump noise and running for long time, eventually showing error 20
There is a problem with drainage. Check the drain line connected to the disposal or peatrap. Make sure it is not plugged. Otherwise you can disconnect the drain line and put a wet vac on it to try to clear the hose
May 20, 2016 | AEG Dishwashers
I have an AEG F55002ViOP dishwasher. It's making a strange grinding sound and showing error code 30. Can anyone advise how to solve this please.
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
The noise what you heard during operation indicates that something is blocking the drain pump.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage then check why the drain pump makes noise.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Good luck.
Dado
Oct 11, 2014 | AEG Dishwashers
How to fix anti flood error on F60860
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Pump will not stop running
It is difficult to answer the question with so few symptoms. The question would be whether the pump stops when you open the door? If not, then should checked for correct door switch, otherwise I think you need to replace the main board. If you see diagram bellow you can see that the motor is driven by the triac which is probable remain in the open position and constantly power supply motor. Some model has relay which switch between wash motor and drain motor and there is possible that relay stuck and motor also running constantly.
22778750-fvdtzpxoyys0i2rs1v4qjxt5-4-0.jpg Dado
Jan 09, 2014 | AEG 21 in. Favorit 45250Vi Built-In...
What is the most usual reason for leakge on the AEG 6050?
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified..
Jan 16, 2010 | AEG 24 in. Favorit 60830 Free-standing...
AEG Favorit 6040 Dishwasher has continuous tone (from Pump?) even when switched off at the power button. It cannot be set to any programme.It overflowed some froth when put on a recent cleaning 'phantom...
This sounds like the anti flood system has triggered. This does put the washer on a pump out mode and the outlet pump runs all the time. The trigger device is a polystireene slab in plastic bracket with miro switch at the bottom of the washer. Dry the bottom out and check for water leaks (hose clamp / hose) and this should solve the problem.
Nov 11, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Anti-flodd Aqua Control
exact same problem here, we had power cut and after power came on the pump was continuously running with error EF3 showing.
This has happened before - design error with AEG
May 27, 2007 | AEG Lavamat 88840 Front Load Washer
Dishwashers Logo
806 people viewed this question
Top Dishwashers Experts
