Question about Cycling
How to adjust handlebars tried to adjust handlebars and loosened ? bike rides like a car with no shocks.
  • 1 more comment
  • momluvtrey1 Apr 21, 2009
    i TRIED TO ADJUST THE STEM. i REMOVED THE SCREWW AND SCREWSS THAT LOOSEN BARS i PULLED OFF BARS TRYING TO ADJUST WHEN i REPLACED AND TIGHTENED THE SCREWS THE TWO ?'S ON THE SIDE OF EACH TIRE DEPRESS WHEN i BOARD MY BIKE.
  • Samuel Charles Spriggs May 11, 2010
    Sounds like the shocks have too much travel in them -- they need to be adjusted for less travel. What are the make and model of your bike. I need to see a picture of it to advise how to adjust.
    This looks like two questions:
    - How do I adjust handlebars?, and
    - Why does my bike ride like a car with no shocks?
    Is this correct?
    Does the bike have a hard ride or are you describing a bobbing motion?
    Problem Solver:
  • 6 Answers
Http://www.parktool.com/
Posted on Apr 25, 2009
How do you raise the handlebars on a next bike
Loosen the center post bolt and wiggle the handlebar back and forth while pulling up. There isn't much height adjustment. You can get a longer center post from a bike shop if you can't get a comfortable adjustment.
Sep 24, 2014 | Cycling
2002 Vstar 1100 is bottoming out with passenger
Replace the spring with a heavier duty should do the job.
Have you tried adjustments in the spring load to stiffen it up.
The rear shock on your Yamaha V-Star 1100 motorcycle assures that the rear wheel is always in contact with the ground and makes your ride much more comfortable by absorbing road vibration and shock while you ride.
But your shock needs to be adjusted for different riding styles, so depending on whether you ride fast or cruise slowly and how quickly you take turns, you may want to adjust the shock to get the most out of your ride.
Remove the passenger seat by loosening and removing the rear passenger seat mounting bolt with a socket wrench.
With the passenger seat removed, you should see two larger rider's seat mounting bolts.
Remove these bolts and pull the rider's seat off of the bike to expose the internals of the motorcycle. 2
Detach the quick-release clips of the ignitor unit found just beneath the seat using a screwdriver. Pull the ignitor unit up and to the right of the bike to move it out of your way.
Remove the mudguard quick-release clips in the same fashion, then pull the mudguard out of the bike to expose the rear shock adjuster. 3
Look for the small numbers on the rear shock adjuster.
On most 2002 V-Stars you should see the numbers 1 to 9 printed on the shock adjuster.
These numbers give you an idea of the current setting of the shock.
The higher the number, the stiffer the adjustment. 4
Loosen the shock by turning the shock adjuster counterclockwise to a smaller number using a spanner wrench.
This makes the shock softer and more forgiving when riding over bumps and uneven pavement, but will feel slower in turns and accelerations.
Tighten the shock by turning it clockwise to a higher number.
This makes the shock stiffer, increasing road response in turns and giving you a better feel of road conditions at the expense of comfort. 5
Replace the mudguard, ignitor unit, rider's seat and mounting bolts, and the passenger seat and mounting bolts.
Take your bike for a ride to feel the difference a turn of the shock adjuster makes.
Nov 10, 2013 | Patch Products Sid The Science Kids Why Do...
How to adjust the handlebars on a bike
To adjust the handlebar position on your Raleigh, loosen the nut on the bottom of the stem extension. Use a 13mm or 14mm wrench, whichever fits. Do not use pliers or Vicegrips! It is upside down, so be careful to turn it counter-clockwise while looking at it from the bottom. To change the handlebar height, you need to loosen the bolt on top of the vertical part of the stem. You may need to tap it with a small hammer to break it loose after it is loosened about 1/4 inch. Now you can adjust the handlebar height, being careful not to exceed the maximum height engraved on the stem. You should also carefully align the bars with the front wheel before tightening the bolt. If you do not understand the terms used here, you should take the bike to a bicycle repair shop.
Feb 26, 2013 | Raleigh Krush 16 Girls Bike 2012 - bikes
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
My RST front fork seals leak. Are they hard to replace? Where should the fork adjustment be for riding around town, and easy, mild off-roading? (I weigh 260 lbs). Can I raise the height of the goose neck...
You could find instant answers to every one of those questions using a search engine and there would be videos.
Regarding the stem search "adjust (or "raise") threadless stem"
Preload on a shock is up how the bike sets down with you on it. "bicycle shock preload"
"replace bearings on RST shock"
One example: http://www.bike-manual.com/brands/klein/om/assets/pdfs/07rst_forks_eng.pdf
Don't mess with steering hardware on your bike unless you understand it. Your life depends on those bolts.
Jun 25, 2011 | Cycling
How do you raise the handlebars for the animator first bike by Giant bikes?
David-
To raise or lower the handlebars, first loosen the hex screw on the top of the stem. One or two turns is all that will be necessary. Next, you will need to stand in front of the bike with the front wheel between your legs to brace it, and give the handlebars a forceful twist to the left or right. This action will break the friction of the handlebar stem and the headtube (the headtube is part of the frame where the front forks and the handlebar stem meet...). With the handlebars loosened you can adjust the handlbars up or down. Keep in mind that the stem has only a specific amount of adjustment available...there is a limit to how far it can be extended up, as indicated by a line marked on the stem shaft. Once adjusted to the desired height, check that the handlebars and front fork and wheel are aligned. Tighten the screw in the top of the stem and you're done!
Hope this helps.
DIYpro
May 03, 2011 | Cycling
How do I rotate the handlebar stem on gmc yukon xl road bike?
If the stem is installed backwards that means it is pointing at you when you are riding? To correct this you will need to remove the handlebars from the stem. This done by removing the two allen bolts front the front of the stem. Now loosen the two(may be only one) allen bolt heads on the side of the stem. Now rotate the stem. Reinstall the handlebars, front mounting plate and bolts (make sure the bolts are tight). Make sure the stem is straight and tighten the allen bolts on the side.
If the stem was installed incorrectly it may be a good idea to have the bike checked over by your local bike shop to insure nothing else is installed/adjusted incorrectly.
Hope this helps. If you need any other help you can contact me at elijah@starbikesfl.com Thank you
Jun 13, 2009 | GMC Yukon XL Road Bike
Cycling Logo
857 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
