Question about NEC Versa LX Notebook
Wireless switch Hi there I have a NEC VersaM400 and am trying to connect to our wireless internet but the computer keeps coming up with the message to turn the 'wireless switch on'...only troup is, I can't find a wireless switch anywhere! Can somebody please help and let me know where it is! Thanks very much!
  • 3 more comments
  • Anonymous Dec 29, 2007
    dont know where is the wifi switch
  • djshaw13 Dec 29, 2007
    dont know where is the wireless switch
  • Anonymous Mar 14, 2008
    i cant find the wireless switch
  • Anonymous Nov 30, 2008
    i can't find switch on help me
  • Anne Martin Apr 08, 2009
    Thx for suggestions. We are restarting to see if fn F2 will get us in.
Hi i had the same problem press fn and f2 at the same time keep held in for a couple of secs that will fix it regards **** best leeds
Posted on Feb 08, 2009
  • 57 Answers
Have a look at the Function keys F1 etc along the top of the keyboard. Often one of these is allocated to switching the wireless on. Posssibly Fn+F1
Posted on Sep 21, 2007
SOURCE:
My Samsung R440 is lately having internet connection problems - it keeps on connecting and disconnecting to the wifi network. Help!
First, be sure that your wireless password or key has not change.
Second, If you are using WPA be sure to either used the right encryption type such as TKIP or AES.
Third, check the distance between your computer and your wireless switch, either you are too far or you are getting low signal.
Finally, reset your wireless switch by pulling the power cord from the back for about 10 seconds, if you are using DSL or Cable, reset your internet provider modem and your wireless switch, then simply connect your modem first and wait for all the lights to come up following by you wireless switch (Reset your computer as well).
Good Luck!
Aug 06, 2011 | Samsung Computers & Internet
Im from d Philippines, im currently seting up my Linksys wireless-G WRT54G Router, after entering the password it says "Setting up router" then the next message would be "checking internet connections" and...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 20, 2010 | Linksys Wireless-G WRT54G Router
Wireless Switch on a NEC Versa. How to turn on?
I think you will find a WiFi switch somewhere around the edge of ya case, move it to the other direction, OR it is the Fn Function key, and perhaps a,little wifi signal printed on a key, press them at same time to turn it on.
Jan 26, 2010 | NEC Versa LX Notebook
My netgear usb connects to my wireless belkin..but no internet ?
this message comes when your computer is not getting the IP address from the router.
There are possible reasons for that.
1. DHCP on the router may be disabled.
2. If your network is secured , then you might not be typing the correct network key.
In both the cases , you will need to check the settings of the router.
You will need to access the router set up.
Click Here for more info about router settings
Nov 24, 2009 | Computers & Internet
A connection with server cannot be established message I keep getting. I can see my router fine but cant connect.
This problem is because there is some misconfigurations that you might have done on the ip address part or either you have added a static ip address which is not getting along with either the DHCP address.
So just check that and try. or else remove it then put it back then try.
May 27, 2009 | Proxim ORiNOCO (8480-WD) 802.11a,...
Wireless switch
the key is usually written on the back of the moden/router if it WEP encryption, it will be about ten characters, but if WAP will be a long one about forty characters ...
Apr 08, 2009 | Computers & Internet
No wireless connection
Hi you could try this...
On the problem PC, go into Control Panel, Internet and Network Connections, then select Network Connections.
You should see a wireless connection if you have a wireless card installed.
Right click the connection and select "enable".
this should activate the card
Jan 06, 2009 | Dell Precision T3400 375W 64bit (bwcw9z6...
Wireless problem
ok try to look for the wireless logo on the keybored and press fn and the key wer u can see the sign of wireless mine locate at f2 press fn and f2 i hope it will
Aug 16, 2008 | NEC Versa LX Notebook
Does NEC VERSA LX laptop computer support wireless internet?
This is a pretty old laptop about 10 yrs. It does not come with wireless support. It probably has Windows 98 installed on it.
You might be able to set up wireless via the USB port.
Here are the specs
May 03, 2008 | NEC Versa LX Notebook
Wirless internet
we'll need a bit more information on the model number to help you out..
Mar 25, 2008 | NEC Versa LX Notebook
NEC Versa LX Notebook Logo
1,403 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
