Question about XO Vision GX1211 XOVision 12" Roof Mount TFT LCD Monitor
Clatch is very loos also car is not going to gear
From few days my car clath is not working poperly cause if i am putting my car clatch down my car is still running . yesterday my car is fully brockdown , clatch is very loos now and if i am tring to putting the first gear there is a sound coming. plese can you tell me what is the problem. somebody told me clatch gone but car was running good there is no speed problem also somebody saying gear box gone .
  • 26 Answers
SparkGap is right. Sounds like your slave cylinder needs changing out.
Posted on May 09, 2008
  • 363 Answers
You are an entertaining speller. This does sound like a broken clutch. Sometimes the seals in the Master or slave cylinder can fail and the hydraulic fluid slips by without moving the clutch plates apart. Hopefully you will take your car to a garage or find a knowledgable friend to help you, this is not a job for beginners.
Posted on Sep 22, 2007
SOURCE:
I have a 1996 Opel astra 2.0l 8valve what can l do to give it more power.
remove 1600 gear box because is too small but when putting a 200i engine u must change the gearbox too and put f20 super boss gear box or put f18 gear box when not finding f20 for 200i because f18 and f20 gearboxes is using bigger clatch plate but f20 is the most pawerfull gear box because I use it on my opel kadett earo and the car is running good
Sep 16, 2014 | Opel Astra Cars & Trucks
What is wrong with my allison 5 speed transmission
possible that the sensor which senses the gear selector position is going bad.
Jul 15, 2014 | 2005 Chevrolet Impala
200cc pit bike wont go in first gear? some one help me please
sounds like your shift lever may have been put back on in a different spot on the shift shaft. make sure it can move up and down with out hitting anything.
Sep 21, 2017 | Suzuko Motorcycles
I have a 94 achieva i got it from my sister, it will run a few days of so then while driving it will start cutting out and the gauges will start going up and down and then it will die. some times it will...
as as far as the dying as soon as u put in gear and easy trick that usually helps those is to unplug the the harness that goes to the transmission cause these cars when the torque control solenoid fails it wont unlock and on ur car thats the only thing electronic is the torque convertor
Jun 12, 2011 | 1994 Oldsmobile Achieva Special Edition
I change de battery in my car kia serento 2007 diesel and the abs light is on. What can I do?
What has happened is the computer for the abs has seen a loos of power to the module and has stored a code. try driving around for a few days and light should go out but if it doesnt then you will need to go to a shop and have the codes cleared. good day.
Jun 08, 2011 | 2007 Kia Sorento LX 4x4
Mazda miata will not go into gear
automatic or manuel wen manuel problem is the clatch
Nov 11, 2010 | 2005 Mazda MX-5 Miata
1988 K75S. Shift indicator says "2", but when racheted "down" to disengage (neutral), it shows "3". I can find a neutral notch with the shifter (confirned by rocking the bike), but the indicator...
your not going to like this!!!!! inside the gearbox is a small bolt that locks the gear shaft to the shifter,, its come loos? all you can do is strip the gearbox and nip it back up again,,,you can test this yourself,,,
try lifting the gear leaver up and down,,,if there is a lot of lift in it,,its that darn bolt loos!,,,go on the net and look at sight, www.maxbmwmotorcycles.com you will find the gearbox on this sight
and that bolt! sorry???
Aug 04, 2010 | 2003 BMW K 1200 LT
PC suddenly shuts down on its own.
in this case pc only shuttdown automatically when the sensor of processors detects or reach the maximum temperature of the system. try to check the CPU FAN if running poperly. RAM also causing sudden shuttdown.
Jul 02, 2009 | HP MINI 2133 Notebook
Clutch pedal is very heavy to push down
If the clutch in your car is hydralic there is no way to adjust that type of clutch. That you describe the clutch as being hard to push and that you have to have the clutch "right down on the floor to engage a gear" is an indication that the clutch is worn and needs to be replaced. If the clutch in your car is pushed by a cable, the cable might be adjustable and if that is the case you might get a few more months of use from the car, but the fix is still the same, you will need to get a new clutch put in your car.
Nov 26, 2008 | 2005 Hyundai Tucson
Car Audio & Video Logo
62 people viewed this question
Top XO Vision Car Audio & Video Experts
Pierre Laplante
Marvin
Marvin
Larry Tezekjian
Larry Tezekjian
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
