Question about Frigidaire Affinity ATF7000E Front Load Washer
The washer door wont shut or lock on my frigidaire affinity
  • 1 more comment
  • autumnrunyan Apr 21, 2009
    The latch broke off inside where it locks and i removed the piece and bought a new latch but it still will not close or lock
  • Anonymous Mar 14, 2014
    Frigidaire washer model FAHE1011MW lid locks but only clicks when on.
  • Anonymous Apr 01, 2014
    Door not locking
  • 116 Answers
In the rubber seal around door to washer tub ensure there is nothing inbetween rubber.
Posted on Apr 21, 2009
  • erickg
    erickg Apr 22, 2009
    the latch must be off a bit for alignment. washers in wrong spot and latch in or out too far.
Frigidaire Affinity ATF7000E Front Load Washer locks the door then it doesn't start. What's wrong?
Good Afternoon Friend,
I understand the door locks on your Frigidaire Affinity washer, model# ATF7000E, and the load does not start. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Affinity ATF7000E Front Load...
Why wont the door lock on my affinity washer?
Good Morning Friend,
I understand the door will not lock on your Frigidaire Affinity washer, model# ATF7000E. I suggest resetting your appliance, by either unplugging it or shutting it off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Affinity ATF7000E Front Load...
WASHER WON'T LOCK DOOR
I understand that that you are having trouble with the door locking on your Frigidaire Affinity dryer, model# ATF7000E. I also see that the lights come on the dial but the door will not lock when you press the button for it to lock. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. When power is restored, run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire Affinity ATF7000E Front Load...
How can you tell when the door lock is bad on a 2011 frigidiare affinity front loader washer
Mike,
I understand that you are wanting to know how to tell if the door lock is going bad on your Frigidaire Affinity washer. One way to tell is if the washer is telling you that the door is not shut or locked when it is. Try to reset the appliance for 3 minutes, by either unplugging it or resetting the circuit breaker. If you are still having trouble with the door lock, I would suggest to have a local authorized technician to come look at the lock and fix it if necessary.
-Best Regards-
Jan 14, 2014 | Frigidaire ATF6000ES Front Load Washer
Affinity washer door lock shuts off. I put a new door lock in and after 20 min it does it again.
Wait until the washer gets done, and then try unplugging the washer for fifteen minutes.
May 06, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have the frigidare affinity front loader washer and just started it up. It stopped about 5 mins into the cycle and the indicator light says dr. I tried to shut the door but that didn't work. So I...
You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
Nov 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
MY AFFINITY WASHER WONT WORK
It is the door lock that may be broken, that's what happened with my maching last summer. The lock is made of plastic if you can imagine. So if you slam the door it can break. A washing machine gets wear and tear how can closing a door be owners fault?
This is a crappy machine in terms of maintenance, it is a maintenance nightmaire!!
Oct 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
905 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
