Question about Konica Minolta Di1610 Copier
Problem with Konica Minolta Di1610
I have any questions in relation to the usage of the copier: 1) on the display I often see the message: "Incorrect T/S type" 2) when I use the copier there are black sheets; when I print, the copies are good. In both cases the maintenance can't say where is the problem. What can we do? Have we to change some part? Thanks in advance Rgds, Angelova
  • 2 more comments
  • angelovan Nov 02, 2007
    thanks for trying :)
    but this method for T/S type is not helpful
  • angelovan Nov 13, 2007
    Hi
    How can I scan documents with Konica Minolta Di1610
    I don't have any software CD
    Thanks
    Hi
    Thanks
  • Anonymous Dec 04, 2007
    i am a user of minolta copier. i
    broke it buy pressing keys/buttons over and over. i think i pressed
    "paper" and "yes" button too fast and too many times.
    it resulted to a "machine trouble" message on the screen. this message is followed by "contact service C01510". :( in the manual, it only says what the error was and not how to fix it:
    "“MACHINE TROUBLE” Error
    This error indicates a serious operational problem. The copier is unable to
    receive any data while this error message is on the display."
    is there a way for me to fix this? can you please help me?
    thank you very much!
  • 4 Answers
Incorrect T/C type means that toner cartridge have not good contact with toner chip, is good to clean this chip, or contact inside magine is not good. Change toner cartridge and if that problem remain, its needed replace contact unit on machine
Posted on Oct 17, 2008
  • Konica Minolta Master
  • 6,763 Answers
Sir/mam, recommend that you have your technician check the ribbon cable (White under the glass) that connects the scanner & exposure lamp to the copier some times the ribbon cable will get lose at the scanner while it moves to scan the document. since you can print fine that leave the scanner section as for cleaning the mirrors they are internal to the scanner assy. that exposure lamp is very easy to break once that happens not good!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 30, 2014
    Problem Solver:
  • 4 Answers
Ther is no error "c01510" - too many numbers.
If error is "c0510" do this :
- turn off the machine -> press & hold the red ( stop ) buton ( in the right down corner ) -> turn on the machine & keep pressing the buton until the default screen appear . If the code reapear repeat the procedure again. If no luck then change the fusing unit.
Posted on Jun 30, 2008
Problem with Konica Minolta Di1610 for mac
Posted on May 15, 2008
For the black copies when copying -- Press utility - 8 and set lamp time to mode 2.
Posted on Apr 03, 2008
  • 163 Answers
Please clean the mirrirs it has dry
Posted on Sep 22, 2007
  • m tariq malik Sep 22, 2007
    clean the mirrors it is dirty
Minolta Di1610 error message - change t/c??? incorrect t/c type??? What to do???
Google it just as you typed it out the manufactures web page will explain better than we can
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_c7b5aba9012a13b2
Aug 26, 2014 | Konica Minolta Office Equipment & Supplies
C dc00 konica minolta c351
CDCXX-trouble related to security.Try to reset:
Turn OFF the copier.Press and keep pressed the Utility key and turn ON the copier.Keep pressed the utility key and wait to Trouble reset message appaire on the display.(1-2 minutes.).Release the utility key and touch the message.Turn OFF the copier,wait 1 minutes and turn ON.If the error code displayed call the technical rep. from Konica Minolta.
Apr 06, 2013 | Konica Minolta bizhub C351 All-In-One...
Can there be another problem besides that? I had a papper jam on a Konica Fax3900.... I fix it, but when I put the tonner again the printer said "incorrect T/C type"......
Power OFF/ON while holding the Panel Reset and No button, then access the tech mode and change the ADJUST in the TC type to 0 for USA.
Dec 30, 2010 | Konica Minolta Di1610 Copier
Problem with di1610.always says change t/c-
TC type is set to the wrong value. Set the TC type value to 5. To change this setting, perform the following:
1. Press Utility
2. Enter the Service Mode (Stop-0-0-Stop-0-1).
3. Select number 4 Display.
4. Scroll to TC Type.
5. Enter 5 and exit.
Nov 13, 2009 | Konica Minolta Di1610 Copier
Minolta di1610 error message
What error message? Does itsay toner cartragie need replaced.
Apr 04, 2009 | Konica Minolta Di1610 Copier
IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Feb 25, 2009 | Konica Minolta Di1610 Copier
Di 1610
this may also be the toner sensor that sits under the drum unit on the machine. I have replaced a few of these
May 05, 2008 | Konica Minolta Di1610 Copier
Konica Minolta Di1610 can't print
hello
is it conect via net or parall port?
have you try to detect the printer by its ip ?
(ping)
pini
Feb 14, 2008 | Konica Minolta Di1610 Copier
Help! i get the "Machine Trouble" error
are you sure thats the right trouble code? reboot machine holding down the STOP button. this may reset this error
Dec 04, 2007 | Konica Minolta Di1610 Copier
Konica Minolta Di1610 Copier Logo
834 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
