Question about Mantis 2-Cycle Tiller
Lock on handle wont work - Mantis 2-Cycle Tiller
I have a roper tiller model #d55ooat serial 1567s01128.
I need the 2 belts for it and i can't find out what the belt numbers are they were destroyed by me of course.
Thanks Steve
Posted on Apr 21, 2009
Cannot open rear drivers side door from outside or inside. door panel is off, door is closed. child lock is on. tried pulling cable, wont move. tried lifting up the child lock with a thin blade
Sounds like the lock mechanism is stuck on the locked position. Since you didn't specify make and model this is a best guess. Make sure the lock is in the unlock position and try manipulating the rod connected to the outside handle (since child lock is on the inside handle won't work)
Oct 07, 2016 | Cars & Trucks
2009 ford fusion left ft door wont open from inside power lock works must roll down window to open with outside handle
Either the linkage connected to the handle has come off, or the piece on the handle inside has broken. You will need to remove the panel from the door and repair or replace the handle.
Mar 28, 2014 | 2009 Ford Fusion
98 accord door handle broke door will not open
A non electric door, (which?) wont open,lock works ok, handle wont open the door.
What can I do to fix it.
well telling the door to us would help, and options.
so no electric locks,
there are 2 levers. one inside and one outside.
so you pull the door card (inside door covering)
and look at both locks , the inside pull, its it working?
then look at the key lock cylinder. is it connected still
and last are both connected to the latch mechanism.
one can cycle this latch lever inside the door shell.
if that fails the latch is busted.
all this is covered in the FSM ,why not read it.? (under body)
free , too.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 25, 2013 | Honda Accord Cars & Trucks
2006 VW New Beetle passenger seat
Check the spring which puts tension on the lever to hold it in the lock position this may have dislodged itself or be broken or possibly bent.
Jun 06, 2013 | Cars & Trucks
My chevy silverodo's drivers door handle wont open and I usualy have 2 lock the truck from the outside
You mean it wont lock? or wont open? the inside door handle? or outside? Opening and locking are 2 different things.
May 14, 2010 | 1995 Chevrolet Silverado 2500
Passenger door wont unlock, key turns in the lock but door wont unlock. Electric locks dont work. Driver door works fine 1991 Nissan pathfinder XE 4door
2006 Nissan Pathfinder rear passanger doors don't open unless opened from insinde handle first. Then will open all the time until central locking is used then same problem occurs
Apr 03, 2010 | 2001 Nissan Pathfinder
Key wont open door on Chevy Colorado, only remote entry works. Even duplicate key doesn't work. Battery fine.
Try spraying some wd40 into the lock loads of it and keep turning the key left to right might free off.
Or it could be a rod inside the door has come off so the lock wont move to unlock, the central locking has a motor to open the door that is not attached to the rod so it can work without the lock.
Take the door card/trim off and have a look at the rear of the lock, should have 1 rod for the handle, 1 for the lock mechanism and another for the inner handle. some are cables but most are rods
It might just have came off the back of the lock, they use very small plastic clips to hold the rod in place, when it gets cold the crack and fall off so the rod fall's out.
Hope this helps
Jan 15, 2010 | 2004 Chevrolet Colorado
Rear door wont unlock
this is not the dead lock? if i am right in thinkin that this is a centrally locked car then the sensor in the door isd set too low mybe slipped as only has to be out a little to cause this, more of an antitheft system than a dead lock.
Feb 24, 2009 | 2002 Volkswagen Jetta TDI
Mantis 2-Cycle Tiller Logo
62 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
