Sound does not work with a dvd. the sound is choppy
My sound does not work with dvds. it is choppy
  • rjivaro May 11, 2010
    Are you using some version of windows?
    If so, how much memory do you have? How fast is your processor?
    If it is a fairly new computer, the next question is what do you have running in the system tray (lower right corner of your screen)?
    The general direction is that you very well might be exceeding the ability of your computer to do everything it is being asked to do. Although it seems ok without running dvd's, when you add the rather demanding requirements of playing audio and video it is unable to keep up.
    If you run Linux the answer is a different animal.
  • 326 Answers
Choppy audio is usually caused by many applications or processes running in the background.
If you already have a Virus scanner, that updates regularly you can skip the Malware scan.
I would suggest three things. A malware scan, a maintenance cleaning, and checking your startup applications.
To run a malware scan goto: www.trendmicro.com/housecall
And follow the instructions on the page, let this run, until the results dialogue window pops up, this make take a while. 1-3+ hours. Just let it run, you do not need to attend it once it tells you it is scanning.
For maintenance cleaning, visit this site to download an application called CCleaner
http://www.filehippo.com/download/file/df09062a5bdcfd3a0a0cf31f7117c0cb566fe5b698d89848911da4e434cb72f5/
After these steps.
To adjust what programs you have starting up in the beginning:
Start > Run > Type "MSCONFIG" > Click the Startup Tab then un-check any program entries that you don't need starting up in the beginning. This does not remove them from your computer, just from starting up in the beginning and taking resources in the background. When you need the program, you can simply click on its link in your start menu. It is your choice what you keep and what to remove.
If these steps do not solve your issue, there may be a complication with your Audio Hardware acceleration. To rectify this issue:
Access your control panel:
Start > Control Panel
OR
Press and Hold "Windows Key Logo" + Press "E" > Click "Control Panel" from the left-side menu (or address bar, depending on your configuration.)
Once their click "Sounds and Audio Devices"
While in the Audio Devices window:
Click on the "Volume" tab and click on the "Advanced" button under Speaker settings.
Click the "Performance" tab > drag the slider for Hardware Acceleration to none.
These directions are for Windows XP generally, but you should find the location is similar in Vista.
It is important to note that this procedure should solve your issue; however, in the event that it does not, this procedure does increase the performance of your machine dramatically. Nothing will be harmed if these steps are followed in their entirety.
If these steps do not solve the problem, please let us know. If this information was helpful to you, please take a moment to rate the solution. Thank you.
Posted on Apr 21, 2009
DVD images freeze at certain points or playback becomes choppy
sounds like you will need to clean laser, there are cleaners you can buy out of walmart for this. Don't know if they work well, I take mine apart and use soft cloth and alcohol then letting dry, works fine for me.
Dec 16, 2007 | Sony DAV-FR10W System
When I play a movie the picture and sound gets "choppy" even with NEW dvds
You can try using another media player.If that does'nt work ,your DVD drive may be bad or need cleaning.Sometimes a bad ram chip can cause the video to mess up.Try playing a movie directly from your HDD downloaded from a website and see if its choppy if its not then its your DVD drive.If it is still choppy it could be the media player your using or it does'nt have enough ram memory/virtual memory.If you have XP change your virtual memory settings and the refresh rate in task manager.(Bring up task manager,go to view tab then update speed to HIGH).
Aug 11, 2009 | HP Pavilion zv6131us Notebook
DVDs Choppy playback
its not a error, your computer is just slow, try using vlc media player to play a dvd and tell me if it plays better
Jun 14, 2009 | Compaq Presario R3000 Notebook
Dvd video running choppy and slow, but sound ok most of time
u should to clean the DVD-ROM & check if ur DVDs or CDS back is clear (there is no crashes on them)
Jun 08, 2009 | Acer Aspire 3690-2050 PC Notebook
E-System laptop with slow dvd playback
This can be a bit of a tricky one to figure out. My initial response would be that you have another program or process that is causing your computer to play 'choppy' video. When you have a newer computer that was recently working just fine and now all of the sudden the video is choppy, it is usually due to another process using CPU cycles that are so important to video playback.
Start playing a DVD, but don't go to full-screen mode. Open the Task Manager. Right-Click on the task bar and select Task Manager. Click on the 'Processes' tab. There is a column labeled CPU, click on the heading 'CPU' twice. This will order the processes in order from highest CPU usage to lowest. The top two processes will most likely be your DVD player and the process that is causing your choppy playback.If the offending process isn't essential (i.e. anti-virus), then click on said process and then click the "End Process" button.
Hope this helps.
Mar 09, 2009 | Computers & Internet
Laptop DVD player producing choppy sound
chasmodem, did u try with other software to play the DVD? Sound like a Cyberlink PowerDVD problem to me.
Jan 08, 2009 | Dell Inspiron 6400 Notebook
Choppy sound and video on laptop
Unfortunately your video card memory is probably lacking. And/or your settings are set too high for your processor to handle. Right click on your desktop, goto properties, goto settings, and select for best perfomance then apply.
CD's play simple audio files. DVD's and games play large video files and large audio files that are choppy on older systems. you may need to upgrade your memory. Make sure you delete all you dont use, run disk cleanup. REstart. Run, disk defrag, Restart.
A good test is goto : www.belarc.com or belarcadvisor.com
They will tell you if yoursystem is uptodate.
You may just be running a older processor?
Let me konw,
Mark
Dec 29, 2008 | Dell Inspiron 1501 Notebook
All my videos dvd and online play choppy and slow Help!!!!!
check and see if DMA is on.
http://www.real-knowledge.com/dma.htm
Dec 26, 2007 | Dell Latitude D800 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
