We detected water under the sink, and after searching, noticed the cable to the faucet sprayer was wet. It looks like the pivot near the srayer may be leaking, especially when switching from a single spray to the multi hole spray. It is a Kohler K-10433 unit. Thank you for your time ! Regards, Bill
There is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
I had the exact same problem and fixed it. I called Kohler customer service at 1-800-4-KOHLER explained the situation and they sent me what they call a 'hose kit'. It is covered by the life time time limited warranty. the kit replaces the the hose between the quick connect and the spray head with all new O-rings, fittings, etc. It was done in about 5 minutes after I got the parts.
Hope this helps.
