Question about Diamond Multimedia ( VC500) Video Capture
Diamond VC500 stops working when any input is connected.
I purchased a Diamond VC500 (for the purpose of streaming to justin.tv) and went through the driver/software installation. I run Vista Home 32-bit on an AMD Athlon 2.01ghz w/ 3GB ram. My problem is that the device is not working; the device manager shows that the VC500 cannot start (code 10).
I disconnected the device from the computer and unplugged the composite cables connected to the VC500 and then reconnected the device. Magically the device has no conflicts and functions properly. I double checked that Adobe Flash Media Live Encoder 3 could recognize the device and it did.
When reconnecting the composite cables to the device, the device immediately stopped working. I've tried uninstalling the drivers, reinstalling them, (I downloaded the specific drivers for Vista 32), rebooting, reconnecting the device, etc. As long as the device is actually connected to some form of input, it stops working.
Any ideas?
SOURCE: how to set up one-touch video capture vc500
You can use either the S-video or the RCA video connector. I don't think you can use both at the same time but I haven't tested that. Also, if you use the S-video adapter, it has no audio so you also have to use the RCA audio connectors when using S-video. Hope that helps...
Posted on Feb 01, 2009
  • 1027 Answers
SOURCE: my Diamond vc500 constantly takes pics HELP!
Check the configuration settings - you may have the automatic frame grab feature activated.
Posted on Feb 09, 2010
SOURCE: Diamond VC500 is not recording my Xbox 360
Mine does the same thing. I think that the problem might be that you have to go to the yellow gear thing and you have to change the recording format to DVD and you have to change the video format to NTSC_M. And make sure you have all of your hardware and your y splitters connected right
Posted on Oct 09, 2010
SOURCE: Diamond VC500 One Touch Capture not recording properly.
Try turning off your screen saver. The recorded file will reset to zero whenever the screen saver kicks in.
Posted on Apr 27, 2011
bronk50
  • 27725 Answers
SOURCE: diamond vc500 "usb device not recognized" i have a
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Posted on Oct 21, 2011
Diamond vc500 "usb device not recognized" i have a
hope this helps you
Oct 21, 2011 | Diamond Multimedia ( VC500) Video Capture
Hi, i just purchased the vc500 today. i installed everything the cds provided me with such as ulead and the driver. when i open up ulead and go to capture, i can see whats on my tv from my laptop but it...
I was having a problem with a USB capture device and found out that if I had anything else connected to the other USB ports it would not work properly. It needed all the power that the USB port can give it... I had the same issues testing it with a couple of my laptops too.
Nov 14, 2010 | Diamond Multimedia ( VC500) Video Capture
No signal from Diamond VC500 Capture Device
I have a similar problem. Sometimes it works fine, but it will often have sound but no picture in the box. Other times, there is no input signal showing when I click on the gear wheel to adjust settings. There is no rhyme or reason to the missing picture. Whe I play it back, I do have the picture - usually.
Jul 18, 2010 | Diamond Multimedia ( VC500) Video Capture
Feb 25, 2010 | Diamond Multimedia ( VC500) Video Capture
My Diamond vc500 constantly takes pics HELP!
Feb 08, 2010 | Diamond Multimedia ( VC500) Video Capture
I am using the vc500 to capture video. It works except
That is a frequent 'fault' with the low cost capture units.q Nothing can be done, other than seeing if Diamond has a newer driver that corrects it.
Jan 25, 2010 | Diamond Multimedia ( VC500) Video Capture
Jan 20, 2010 | Diamond Multimedia ( VC500) Video Capture
How to set up one-touch video capture vc500
Aug 26, 2008 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture Logo
864 people viewed this question
Top Diamond Multimedia Televison & Video Experts
Lawrence Oravetz
David Gust
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
