Epson Stylus Pro 9600 InkJet Printer Logo
Posted on Sep 21, 2007
Epson sp9600 im using my epson sp9600 for over a year, and just lately i have seen an error flashing in my lcd panel saying maitenance req. 0040 i dont know if i got the number right. what does this code represents please help me sir/ma'am. tnx in advance
  • Anonymous Feb 14, 2008
    fault code 0040
  • Anonymous Mar 05, 2009
    error 0040 machine still works but after contacting epson they said it needs cleaner fix and they want a basic £400+ TO FIX IT?
    Can any one advice how to fix it and save the fees
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1769
Points
Maintenance 0040 shows on my printer. I tried pressing the only down arrow it has and the enter button simultaneous after shutting it off but it's still showing. Can anybody offer any help?
[email protected]
Anonymous
Level 1:
  • Contributor 54 Answers
  • Posted on Sep 21, 2007
Anonymous
Contributor
Level 1:
Answers
54
Questions
0
Helped
47877
Points
93
Aha and your printer is not functioning right now isnt it, or it is still operational, either way that error must be solve or you will never use your printer. this error means that your pump motor is near end about 5% of its life is left. here is the sure solution for your prob. turn off your printer then press the left, down arrow and enter simultaneously then power on the printer. inside initialize the sponge and cleaner then turn off and on your printer. note: you will have to replace your pump cap assy. if it is already poor in cleaning otherwise your printhead will suffer.
  • Anonymous Apr 18, 2013
    I get into the mnt. tank counter (epson 4880) pressing the left, down, up arrows and powering up, but I can't change the counter.
A
Anonymous
Errore 0040 epson pro 9600
PRINTER SHOWING 'SERVICE REQ E300'
Sadly this is a serious error requiring a replacement Laser Unit - if you are lucky. It may also be a system board error that is falsely reporting the error.
This printer is likely to be beyond economical repair.
We have an EPSON STYLUS PRO 9600. We have received the msessage MAINTENANCE REQ 0040. Can you help us, please? Thank you very much.
The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
How much do you charge for replacing the Maintenance Tank Sensor on Epson SP9600. I just replace the maintenance tank and the machine is showing no maintenance tank. Thank you!
<br />Howdy:)<br /><br />We are not associated with Epson and do not do actual repairs, but I have found the list of authorized parts providers for Epson sp9600<br /><br />http://www.epson.com/cgi-bin/Store/support/supAdvice.jsp?BV_UseBVCookie=yes&amp;type=highlights&amp;noteoid=153590<br />You can cut and paste the url into your browser's address window and see the selection for your area. I hope you find this useful:)<br /><br />
3helpful
How do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
tomas
how do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
Solve this problem:
11helpful
2answers
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
8helpful
2answers
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
5helpful
Service required error 0001002d
2answers
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
