Question about RCA R52WH76 Television
HDTV I hit some button on the remote and now the picture moves in stop action mode How do I get it back to normal???
  • 3 Answers
Hit the ok button on the remote, mine does it when that button is hit so try it. mine in an RCA tv
Posted on Jun 10, 2009
    Genius:
  • 1,153 Answers
You can manually reset, by unplugging for about 1 hr. this may help not sure what set so don't have much insite.
Posted on Sep 21, 2007
SOURCE:
I Lost picture. Went to press mute button on remote and pressed last button instead. Now i can't get picture back.
If you hit the "last" button again, it should take you back to the channel you were on before you hit the button. when you lost the picture, was the screen blue? black? If you hit the "menu" button, does the menu come up?
Jan 11, 2013 | Vizio VW37L 37 in. LCD HDTV
Cant get movie to come on.it says to hit play button.cant find any such button.picture comes on but that is it
The Polaroid TDA-03211C has the Play/Pause and Stop/Eject buttons on the TV on the side of the TV near the DVD slot. They are separate from the other control buttons. (They are closer to the back of the TV relative to the DVD slot with the stop button the lower of the two. The play button is just below the media card slot behind the DVD slot.) The original remote also a Play button (center two rows above the channel and volume toggle buttons).
The manual for the TDA-03211C is available as a PDF from HDTV solutions: http://www.hdtvsolutions.com/pdf/tda03211c_ug_en.pdf . See page 12 (page 14 of the pdf) for the controls on the TV and page 14 (page 16 of the pdf) for pictures of the remote.
I hope this helps.
Sep 04, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
We need the device code of the panasonic Tc42px24 plasma HDTV thank
Hello
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save
OK.
Feb 13, 2011 | Panasonic Tc42px14 42 in. TV
When we watch tv, particularly football, on our lg 50pq30, the tv cuts off the image so we can not see the score at the top or bottom of the screen regardless of which setting we chose
Hello: Seem you are in zoom mode, try hitting the format putton on the televisions remote and if you are using a cable box and using HD check for a picture format or aspect button on it also. You will want to be on 1080i normal or stretched. The cable box and television will use different modes for aspect, try using only one of the remotes when changing aspect ratio buttons or screen size.
Nov 24, 2009 | LG 50PQ30 50 in. Plasma HDTV
Sony 46in projection tv
To reset this unit start with pwr off. Then on oringnal remote press the display button, the number 5 button and then volume up button and then hit the power button this will take you into the service mode menu, Press the number 8 key and then hit enter, this will set the unit back to factory specs. The set should turn off itself and then power on itself to channel 3, All user setting before this procedure are reset to factory mode..
Please leave comment THX
Nov 04, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
No video/audio when pressing remote control or on the TV set
Moved my TV to another satellite receiver.
I received picture & audio.
Then I moved the TV back to its original position.
Now it works OK.
I probably hit a button that shut off my picture & sound.
I am mystified.
Thanks anyway.
Gerry............................;-))
Apr 13, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Picture too large
Find the "wide mode" or "zoom" button on your remote or something similar.
Nov 16, 2008 | Polaroid PLA-5048 50 in. HDTV Plasma...
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
No Picture
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture size
They may have gotten to the zoom function. There is a zoom button on the cncealed part of my remote. Hit the zoom button to cycle through all the screen sizes.
Oct 26, 2007 | Olevia LT37HVS 37 in. LCD HDTV
RCA R52WH76 Television Logo
115 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
