Question about Harley Davidson 426290 AM/FM Radio
2001 Ultra CB radio does not transmit. It receives fine. When you key the mike, the CB radio display (squelch) goes blank, headset sidetone is very weak.
  • 4 Answers
Hi the radio internall will have a driver and final transistor these are for the output signal or tx. you might find that the final transistor is faulty and needs replacing these fail due to incorrect swr or tuning of the antenna or cable / connector shorts. dont over look a bad microphone connection wiring on either end and internally on the ptt switch
most common driver is 2sc2166 and 2sc1969 for 27mhz amm & ssb
Posted on Jul 22, 2009
I have a Midland 75-785 hand held, It was working fine then I went to use it and the squelch control is not working ( I get lots of static) radio still works. Sends and receives, but when I turn the...
what time of day are we talking here? usually skip is so heavy from 0800 until 1600 that no radio has a chance of transmitting or receiving.If you turn the squelch the other way what does it do?
Jun 22, 2011 | Midland 75-785 Handheld CB Radio
I have a Cobra 18 wx st. I am not able to transmit anything on it. I have checked the antenna cables and and all external connections. I receive all the wb just fine but the CB gives me nothing. I tried a...
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike. With the WX band working, the above may not apply.
See if you have a carrier...signal going out, but no modulation. Get your Tech to check the mike wiring/circuitry inside the radio, also.
Jul 06, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Sincgars system in 92F configuration, no sidetone in VIC-3 headse
check the wiring of the antenna ... i had the same problem a few days ago and it was that
mike@bvsigns.com
Aug 31, 2009 | Electronics - Others
2005 Ultra Classic CB transmits fine, does not receive at all . Replaced headset and cables, no luck.
Have someone check your SWR readings (using a SWR meter) on the antenna. This should give you some information on reception.
Jun 26, 2009 | Harley Davidson 426290 AM/FM Radio
Won't receive audio or any noise with squelch all the way left
Perhaps a faulty connector on your coax cable. Get it fixed or replaced you coax cable with a new one.
Mar 24, 2009 | Cobra 19 Ultra II CB Radio
No squelch
Yep that should happen.
Green or no color in receive mode
Red when you key the mic to let you know when you are transmiting
Feb 28, 2009 | Cobra 29 LTD CB Radio
Not real sure
Make sure that the mike gain & RF gain controls are turned clockwise & the squelch is counter-clockwise.
Jun 07, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Harley Davidson 426290 AM/FM Radio Logo
226 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
