Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
My pool pump won't prime
I'm opening our pool for the season and i got the pump to prime once with the main drain only i slowly opened the skimmer line and it was doing fine until i had it all the way open..air got sucked into the line and it lost suction... now when i try to fill up the basket with water to prime it ,it just continuously runs into the pool and is slowly filling it up...... please help me!!!!!!
  • Samuel Charles Spriggs May 11, 2010
    It sounds like your skimmer valves are leaking badly allowing air to be pulled into the pump priming pot. Skimmer valves can leak around the handle as wall as around the seal between the top of the valve and the valve body. First tighten -- if this does not improve the situation, disassemble, and check O-rings -- replace bad ones, lubricate and reassemble.
    Problem Solver:
  • 16 Answers
As previous poster said get water above skimmer line to keep from pulling in air. With the multi-port valve in closed position, I fill the filter with the water hose first, then replace filter cap. With the intake valve set to skimmer, I fill the pump basket with a water hose until it will take no more. Then replace pump basket cover. Then take the garden hose running full blast and stick it down the skimmer. Then I set the multi-port valve to 'filter' and turn on pump.
Posted on Nov 03, 2014
    New Friend:
  • 77 Answers
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Posted on Apr 22, 2009
Why would it lose prime
Many reasons!!! Air is getting into your plumbing system, before the pump... On the suction side. Our at the shaft seal. Check all threaded fittings in front of the pump reseal as required. If above ground pump is easy to check all the way to pool. Which will include skimmer and main drain. If in ground, very difficult to check skimmer and M/D. Good luck.
Feb 21, 2015 | Pool & Spa
Why does pool pump have way more suction than it used to have after 40 yrs?
you can put a ball valve on it and open only 3/4 way or if you have an inground open the main drain and the other skimmer did you upgrade your pump?
Sep 08, 2014 | Pool & Spa
Hello I have two Baker Hydro Skimmers in my 30 year old pool. From what I can tell the main drian was capped. Im only running on skimmers now. The drain is opened and I'm going to a side by side drain...
It is highly advisable to have a separate return line from any bottom or side drain plumbing. It is also advisable to have an on/off valve on this line. This allows for greater control of your filtration, assists when repairs are required and is most useful when seasonally closing the pool.
Hope this helps,
Osko Pool n Spa
http://www.oskopoolnspa.com
Jul 22, 2013 | Waterco 00B9012 Baker Hydro Skimmer Parts...
Prime
Hi to prime your pump you fill the strainer basket with water and make sure all connections are tight with no leaks. Once you seal the lid turn on your pump and it should prime. If you have an issue you can force water through the suction line by putting a hose in the skimmer and force the water through your suction line. Time to Open the Swimming Pool
Jun 06, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
I have a Jacuzzi AO Smith 1.0hp pump for an inground pool - my husband turned off everything to clean the basket in the pump and now we cannot get it going again. We filled up the pump to prime it, put the...
Ok I assume the pump is running? Check the lid again to be sure the "O" ring gasket is in place. If it leaks, it will draw in air, and won't flow full flow. Also check the lid for cracks. If you have seperate valves on your skimmer and main drain, I ususally close the skimmer valve and open the main drain valve fully. Once the pump is pumping full, I usually open the skimer fully, and only open the main drain about 40%. Another tip would be to close these valves on the suction side when you clean the basket,and do it rather quickly, and you won't have as much trouble loosing your prime.
Jul 07, 2010 | Jacuzzi Pool & Spa
Pool Pump does not Prime.
CRAIG .. IF ITS A STA RITE PUMP DURA GLASS YA GET IT FIXED ! SHOULD COST ABOUT 75.00 SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP REPAIR GUY . ASK IF HE DOES FREE MOTOR TESTING
May 20, 2010 | A.O. Smith SQ1102 Pool Pump Motor
I need to drain my inground pool with a heyward pump the water level is down just past the skimmer, do I need to close a valve so the pool will continue to drain from the main drain in the deep end? or...
You can try this but you run the chance of loosing the prime and burning up the pump. if the water is below the skimmer your already further than you should be.
What you need to do is get a submercibal pump. You can usually rent one at one of the big home centers, (Home Depot, Lowes...) or a rental yard. This will cost twenty or thirty dollars and that is a lot cheaper than a new pump. Also if your planing on cleaning the pool it will pick it's own prime so you can wash and rinse the pool.
Mar 21, 2010 | Pool & Spa
How do i drain pool with hayward valve? setting is on waste but only drains hottub then looses prime.
you do need to set the filter valve to waste but you need to make sure the valve on the suction side of the pump is pulling water from the pool instead of the spa. Also, if you have a separate skimmer and main drain valve on the pool suction, make sure the skimmer valve is turned off. Otherwise, you will keep losing suction. If you don't have a separate skimmer and main drain valve, you may not be able to drain the pool with your equipment.
Nov 08, 2009 | Hayward SAND FILTER, PRO SERIES
Can't get pump to prime
Is this the first time starting up this season? 1. Make sure pool level is up. 2. Check lid gasket and coat with silicone based lube. 3. Try to fill skimmer or drain line as much as possible. 4. If there ara two suction lines coming in then try to prime pump on just one of them. Gradually open second valve after prime is achieved. 5. If pump sits more than two feet above pool level then you will have to allow ample time for priming (it may take a couple of minutes).6. Make sure strainer drain plug threads are taped up. 7. If able to, try priming through another line.Good Luck
Apr 22, 2009 | Pool & Spa
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
1,113 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
