Question about Welding Tools
New welder worked good for short time then gas won't stop coming out of torch end
  • Rick Reichlein May 11, 2010
    Does it feed the wire and the wire is live when the gas is not working?
    Problem Solver:
  • 5 Answers
There should be a gas selonoid switch on the inside of the case where the gas hose attaches. sounds like its stuck open. may be defective. try pulling on wire off of the switch and see if it still does itor if the gas still flowes.should be connected with spade connections so its easily pluged and unpluged
Posted on May 03, 2009
I have a maxus pro125 welder and the only thing that happens when I turn it on is the fan starts. It doesn't arc or feed wire. What could be the problem.
Hi Ben:
Basic question................ Is the ground clamp attached?
Second question..... Did it ever work?
Third question........What happened to make it stop working?
Jul 15, 2016 | Welding Tools
If I am using a 150A High frequency TIG welding machine, would you recommend a torch with gas control valve or not
You should control the normal gas flow at the bottle with a flow meter. Your welder may have additional settings such as 'post gas' and 'pre gas' to start the flow before you press the button or keep it going for a short time after you release it.
Sep 07, 2011 | V, Inc. Weldcraft Wp17v Weld Like A Pro...
My 180 MigPak will not deliver argon to the torch. The tank is turned on. But won't let gas flow when the trigger is squeezes. Stick the torch in water no bubbles appear. What could be the problem. ...
Your gas hose or torch could be bad or plugged. Your gas solenoid on the welder itself could be bad. Disconnect the torch gas hose at the welder and see if you have gas coming out of the welder itself.
Jun 28, 2010 | Lincoln Electric Lincoln Easy MIG 180...
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
105 Turbo Model 90778 welder. Took apart the gun/handle because it was not feeding the wire corretly. Put back together and it shorted out. Don't have an exploded view of the handle, to see if anything...
most wire feed problems stem from WF rollers, liners, clutch mechanism on the reel, or contact tip, very rearly on the torch, Torch units are cheap enough and come in a wide range and lenghs, avoid long length cables unless nessasary. you can obtain a drawing of torches from the torch manufacturers
Jun 30, 2009 | Welding Tools
Spool wire starts to melt while on the spool
1] Switch off the mains power,remove the torch from the machine,ther should be a button or switch on the unit to feed the wire, push or switch these and observe that the wire feeds and dose not heat up, if ok then you have a short in the torch, a new torch assembly is required,if the wire heats up with the torch removed, the wire spool is shorting out, remove the spool and check wiring in and around the feed motor, if you can't see anything check for a voltage from a good earth and on the rollers, if you have a voltage then the motor is faulty.(earthing out) a P.A.T test should show exactly where this is.
Feb 16, 2009 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Tig my pudle melts into gray not shinny
Ensure you have the correct angle when using the torch = 22-24 degrees from vert: this will provide good gas coverage. setting should be 15 - 20 ltrs using a "flow meter".clean the material thoroghly then weld , dont clean then leave for a long time.
Argon gas sometimes can be contaminated and cause heavy soot on the weld bead,
TIG electrode should be Zirconiated with a rounded end not pointed.
Use forehand ,method
Feb 02, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welder not welding
The contact tip is the main source of power, if the tip is bigger than the wire then you will not get a proper conection, the earth clamp is a essential part of the system make sure you have a good earth and all the conections are tight
Jan 14, 2009 | Clarke Power Products Clarke 130EN Mig 110...
MIG wire is always hot without pulling trigger
Check your manual, there are a lot of mig units on the market that are alway "Live" alternatively, the relay has either shorted or you have wirering problem on the switch.
Jan 07, 2009 | Welding Tools
Welding Tools Logo
77 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
