Question about Bosch PRO1072SM 10 Inch 72T Miter Saw Blade
Cant remove Bosch 10'' mitre saw blsde nut too tight.
Nut is too tight which way do you turn it? tried counterclock wise with a lot of force. Any way to loosen it?
    President:
  • 1,996 Answers
Try the other direction. It seems to me those are reverse threaded....so you have to turn the bolt clockwise to loosen.
Also see here: http://mdm.boschwebservices.com/MDMCache/t10/0000000/r00164v-1.pdf
(page 11)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 21, 2009
How do you change a blade on model 36-075
Lots of saws have left hand threads on the nut that holds the blade in place. It is designed so that if the saw starts up and the nut isn't snug, the nut and the blade slipping on the turning arbor would tend to tighten the nut as they slip against the force of the spinning arbor.
1. Unplug the saw.
2. Hold on to the blade tightly with one hand.
3. Put the wrench on the arbor nut and turn it in the direction you would turn it as if the wrench were turning the blade to cut wood.
If you've previously overtightened the blade, jamb a piece of wood against the teeth and the saw table top and then follow step 3.
If the motor is on the left side of the blade as you face the saw, then it's a standard right hand nut.
If the motor is on the right side of the blade as you face the saw, then its a left handed nut.
Sep 17, 2014 | Delta Circular Saw Blade, 10 Dia, 50T -...
Trying to remove fan clutch,which way does it turn?
YOU NEED TO HOLD FAN CLUTCH WITH A CLUTCH TOOL THEN LOOSEN THE LARGE NUT RETAINING THE FAN AND CLUTCH ASSEMBLY REMOVE FAN TO CLUTCH BOLTS AND NUTS COUNTERCLOCK WISE.
Apr 01, 2011 | 2000 Chevrolet S-10
Just bought a new 455 Rancher, within 15 minutes of use the chain fell off the guide. Could not put this chain on guide again. Tried brand new chain and within 15 minutes of use, chain came off of guide...
if you loosen the nuts holding the bar on there is a tension screw on the opposite side from where the nuts are you should see it if you look from the front of the saw by the muffler you need to use it to put the proper tension on the chain if you turn it clock wise it should move the bar out tightning the chain you want a tiny bit of slack in the chain it should not be dogged down tight with the tension screw if you go counterclock wiseit should release tension. once tight tighten screws to hold on bar and spin chain by hand should be able to spin chain if not it is to tight. hope this helps
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do you change the blade in a Ryobi 2000 watt mitre saw?
Ihave the same saw and i like it a lot. There is awrench that clips in near the handle that fits the bolt also there is a lockon the front of the saw under the trigger that needs to be press in this will lock the shaft . The bolt is left handed so you have to turn it clock wise to loosen its the oppisite a normal thread so it dosn't loosen whale you are opperating it. Pull back the blade gaurd loosen the bolt remove note the way the washers come off theres only way they fit so look at them as your removeing them . Put the new blade on the outer washer push the shaft lock bottem tighten and its ready to use.
Jan 08, 2011 | Ryobi 10 In Miter Saw With Laser
Motor replacement for Bosch Mitre saw
Most often the entire motor doesn't go bad. It would be a componen't like armature, field, brushes, Switch. I very seldomly see a whole motor go bad. look for a single problem. The saw is not junk it is very repairable with some testing of parts.
Jul 12, 2010 | Bosch 10" Slide Miter Saw
I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Mar 15, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Putting on a saw blade
Well M8:) try to to unloose it backwards, It dosent loose as usal, you need to posh the otherway. Nornaly you loose things from right to left, this one (and other items that cut) you loos from left to right.
Good luck to you
Dec 18, 2008 | Bosch 12" Compound Miter Saw 3912
Bosch PRO1072SM 10 Inch 72T Miter Saw Blade Logo
435 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
