Question about Garmin GPSMAP 176C GPS Receiver
Will not power on
Hi guys, I have a Garmin GPSMap 176C that will not turn on. It was working fine before I put it up in a closet for about a year. I stored it without batteries and it was in a dry, climate controlled environment. I took it out a few days ago and put new batteries in it to use it. The unit would not power up. I tried a different set of new batteries with the same result. Any help is greatly appreciated.
  • hisrwmoore Nov 15, 2009
    Thanks for the suggestion Yorick, but I tried new non-rechargeable batteries. I even tried a different set of new batteries from another package just in case the first set was bad. Still not working.
Did you use rechargeable batteries? The Garmin seems to be extremely picky about enough voltage. I had good rechargeables which I use in my foto flashlights, but they did not suffice for the Gamin. Simple non-rechargeable batteries ones solved my problem. Not good for the environment, but for my bearings...
Posted on Sep 01, 2009
Dark screen
It's either the logic board or some component that has gone bad. No real way to repair it, unless you tear it down and it's maybe a bad joint or something simple like that.
Best I can tell you to do is to FULLY discharge the battery, as in turn it on, let it die and keep pushing the power button to make sure it's dead. Takes about 48 hours. Once you do that, plug it in and DO NOT try to turn it on, just let it do it's thing and see what happens. Maybe hooking it to a computer after that and seeing if an update will help, also make sure that if there are any cables, external antennas, or cards plugged into it, to remove them during all of that. Best of luck for a resolution.
Nov 02, 2017 | Garmin GPSMAP 176C GPS Receiver
Garmin gpsmap 176c
CHANGE POWER LEAD
Jul 02, 2013 | GPS
Hi the screen on my 176c is so dark it can barely be read. I have to turn the light on to see whats going on.Is there any way to restore it to its former glory cheers ......john wainwright. ...
John, the light sensitive IC has failed. This is a small piece of electronic wizardry that adjusts the brightnessdepending on the ambient light. At night is is supposed to add brightnes and in sunlight reduce it
The sign of failure may have been early but you didint notice it. They often turn on ok then suddenly in daylight the screen will darken, turning the unit off and on resets it for a while. however it gets worse as time goes on.. iT is not a DIY and has to be sent back to the manufacturer for correction.
Contact Garmin for a quote before submitting it for repair, you might need a chair to sit on when they give you an answer. Contact the service support in 7 hills NSW 1 800 235 822
Please rate my help++++ Thanks forf using FIXYA
Aug 04, 2010 | Garmin GPSMAP 176C GPS Receiver
Need repair 176C GPS ok using plug power but battery damaged internal batt connection and will not turn on using int batt device is in NY buddy has few bucks & not wanting to buy new
I have done repairs to similar thing, what I have done, is get a "Pack" of batteries, with leads on them, similar to a cordless phone battery, but the same voltage as the ones the GPS uses, now, solder the wires onto the correct terminals. or the circuit board, make sure you rid every trace of corrosion too.Your good to go.
Feb 23, 2010 | Garmin GPSMAP 176C GPS Receiver
The GPSmap 176c does not turn on. I have put in new batteries and cleaned the metal parts of the battery receptors
Do you use rechargeable batteries? The 176C seems to be extremely picky about the voltage. I had the same problem. Afer changing to non-rechargeable batteries, everything works fine again. Not great for the environment, but for my bearings.
Jul 12, 2009 | Garmin GPSMAP 176C GPS Receiver
Batteries last only 20 minutes?
NiMH batteries work on less voltage than Alkaline batteries, so the unit thinks the batteries are low when they are just the wrong type, put Alkaline batteries in {and turn off the backlight if possible} and you will get your 8 hours of use.
Jan 21, 2009 | Garmin GPSMAP 176C GPS Receiver
Battery contacts
The only way is to send it back to Garmin. They will not sell the part. I just folded a piece of aluminum foil and poked a hole in it and unscrewed the contact, placed the foil under the contact, screwed the contact back down and then folded the aluminum down so the battery end could contact it. .
Jul 29, 2008 | Garmin GPSMAP 176C GPS Receiver
My 176c is not responding
get the download (updater from garmin website , download it then hook up 176c to computer and run file .if it doesnt go thru hit power and try again if you get the screen under a good light so you can see it will say downloading when this is done your screen will be back to normal .I dont remember if the unit is on when it beeps or off .try both ways if it doesnt work replace batteries as even though your not seeing the screen the unit is still on like i said ; fresh batts and try it and if it doesnt work hold down power key for a second or two and try again. good luck PS garmin doesnt know this i figured it out myself ...bob
Feb 24, 2008 | Garmin GPSMAP 176C GPS Receiver
Garmin GPSMAP 176C GPS Receiver Logo
279 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
