Question about Whirlpool Washing Machines
Washer drum is tilted and water splashes out while filling.
My Whirlpool washer drum has become tilted, probably the result of an uneven load. Now, when it's filling, the water splashes against the rim and flows into the outer area of the washer, eventually flowing out from underneath the base. I have to tilt the drum back into place while it's filling to make sure the water goes directly into the drum....which is impossible when it's spinning and rinsing. How do I get the drum back in place...permanently? It's a Whirlpool Heavy Duty Large Capacity Washer .. Model #LLR6144BQ1
Coldcut
  • 1554 Answers
SOURCE: My GE Washing Machine Steel Drum is tilted
You have likely stretched one of the side support springs or knocked it loose, you will have to open the side/back panels to see.
sometime you can just pull it out tilt the washer back and see it from underneath. disconnect power to live.
Posted on Feb 03, 2008
SOURCE: Whirlpool Heavy Duty Super Capacity Plus top loading washer
i see water around the bottom outside of my whirl pool heavy duty spuer capacity washing machine...in the spinning cycle it appears to be going out the drain hose and drainning ok???
Posted on Aug 25, 2008
jsrock516
  • 5911 Answers
SOURCE: Washer not spinning/agitat
This problem is usually attributed to a broken motor coupling. The following link provides step-by-step instructions on how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is a small 3-piece component that is installed behind the drive motor and couples it to the transmission. It is common for these small couplers to break as they wear out. The key symptom in determining the cause is the fact the washer will not agitate, but still drains. The reason is because your drain pump is mounted on the front of the drive motor and will still run as long as the drive motor is running. The part number is provided in the link I gave you. A replacement coupler can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best price. Make sure you "Search by Part Number" when looking up the part. This shouldn't cost more than $20. If you do not wish to order on line, take the part number I provided and go to your nearest appliance parts retailer. This is a common item they should have in their inventory.
If you have questions along the way, please let me know. I hope you find this information helpful.
Posted on Mar 03, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool heavy duty super capacity plus machine slow to fill.
This problem is commonly attributed to a water inlet valve that has become clogged with sediment or calcium deposits over time. If you live in an area that has hard water, or if you use well water, this is a common problem. You can remove the valve and attempt to clean it by soaking it in a 50/50 solution of distilled vinegar and water, or you can simply replace it all together. If you're going to go the route of removing the valve, it makes better sense to replace it, rather possibly having to repeat the steps again if cleaning the valve doesn't work. The following link explains how to access and replace one:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts can be purchased at any of the following web sites:
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. If you do not wish to order parts on line, look up the part numbers on the Sears site and check with your nearest appliance parts retailer. These is a common part that may be commonly found in their in-store inventory. The average cost is about $30 - $35.
If you DO wish to attempt to clean the valve to save some money, submerge the valve in a 50/50 solution of distilled vinegar and hot water for about 30 minutes and flush with clean water. DO NOT submerge the electrical connections.
You may also try any number of calcium, lime and scale removers on the market. CLR comes to mind as a good product, but use in a well ventilated area. It has some very strong fumes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Posted on Mar 18, 2010
Testimonial: "Great advice. I will follow your clear and easy steps. Sounds like one or the other solution will be fine."
marka19
  • 1430 Answers
SOURCE: Whirlpool heavy duty super capacity plus machine. ...
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on May 20, 2010
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
Hardley any water going into washer...keeps tumbling with hardley any water
Low water? This washer uses very little water to provide good cleaning results. You will see little or no water splashing in this washer. This is normal.
http://www.whirlpool.com/digitalassets/WFW9250WW/Use%20and%20Care_EN.pdf
Mar 14, 2015 | Whirlpool Duet 3.5 cu ft Stackable...
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
Why does my front load washer not fill up with water like top load washers
Most modern washers use little water. Let it do a wash cycle and see if the results are satisfactory. If not good enough there is a way to allow more water to be used. Give it a go first.
Aug 29, 2014 | Whirlpool duet Washing Machines
Unbalanced load
it could be your pump blocked and not discharging the water it will become unbalanced not spin
Nov 22, 2011 | Whirlpool WTW6400SW Top Load Washer
Whirlpool Duet Water in drum when washer isn't running
Water fill valve ..Also.try outlet pipe not too low, water could be comming from sink back into machine...
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water filling up in Front loading Whirlpool washer
sounds like you have a faulty water valve that does not close when the power is not supplied to the machine.or a problem with the cotrol board supplying power to the valve when the unit is not in use
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water remain in the machine
the washer has a fluid filled ring around the drum to balance it as it spins, assuming do not actually see or feel water you may be hearing that liquid.
Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whilpool front end loader leaks water after done filling
theres a hole in gasket (bellows),,,,now also check your detergent draw if water pressure is to high it will splash over and come down inside of cabnit...
Dec 24, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
164 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
